It is currently Thu May 23, 2013 8:03 pm
 Post subject: Olympus E410 - Lenses
PostPosted: Tue Nov 02, 2010 5:14 pm
Hi all newbie here!
I've been searching around for a 300mm lens for the above camera but can only seem to find the official olympus zuiko one, which at £250+ is out of my reach at the moment. I was told a while ago that Sigma did a compatible 70-300mm lens for £150 but I cant seem to find one anywhere used or new. Seem to have a limited range of lenses with the four thirds system. I've currently got a 40-150mm olympus lens but its just not quite enough for bird photography, I think 300mm would be sufficient though. Can anyone help?
PostPosted: Wed Nov 03, 2010 1:44 am
I think the Olympus 70-300 is basically a re-badged Sigma, but I don't think sigma make one themselves. They do a 70-200 and a few others, but not within your budget.
The Olympus 70-300mm is the best option for birding on a budget. there's nothing else that compares on price I'm afraid.
Try this lens/body simulator: http://www.four-thirds.org/en/special/matching.html
PostPosted: Thu Nov 04, 2010 3:06 pm
If you want 300mm, then the Zuiko 70-300mm is the cheapest choice. Not to mention that it is a capable macro lens as well.
I also thought that the Zuiko 70-300mm is based on a sigma lens, but I have read that Olympus declines this.
Maybe you should take a look at the lens gallery. There are some shots done with the 70-300mm by others and myself.
Olympus E-30, ZD 9-18mm 4.0-5.6, ZD 50mm Makro 2.0, ZD 14-54mm 2.8-3.5, ZD 70-300 4.0-5.6
Light travel equipment:
Olympus EP-2, µZD 14-42mm , Panasonic 20mm 1.7 pancake.
Cullmann Trento IT Daypack
PostPosted: Mon Nov 08, 2010 9:54 am
Thanks for the responses :) looks like i'll have to be patient and put some pennies away!
PostPosted: Wed Feb 02, 2011 10:08 pm
One thing to consider:
Your E-410 has no image stabilizer. This might be a problem when it's not very sunny.
