Thought I'd update here since I gave it field usage the other day.
On the zoom function, I found I tried it once and didn't use it after that. While it does what it says, it was very hard to use hand held for higher magnification macro (> 1x). Also, I was reaching the limits of the focus screen as the grain on that became visible with that increased magnification. So overall I used it in the lower magnification state.
I found aiming to be a bit difficult, but that will probably improve as I get used to it. My brain couldn't compensate enough for it and I often found myself pointing far above the subject.
Even with the angle finder helping you put the camera lower, it wasn't as much as hoped. I was sitting down, and there's only so far I can bend down from that position. So, yes it was lower than normally using the viewfinder, but you're not going to get ground level shots still without getting further down there yourself.
Overall, the use for hand held bug hunting is of mixed value. I think its strength is more for when you can get away with using a tripod to get rid of the holding issue. For hand holding really low, I think the external LCD displays might be a better choice.
_________________ Canon DSLRs: 7D, 5D2, 1D, 600D, 450D full spectrum, 300D IR mod Lenses: EF 35/2, 50/1.8, 85/1.8, 135/2+SF, 28-80 V, 70-300L, 100-400L, TS-E 24/3.5L, MP-E 65, EF-S 15-85 IS 3rd party: Zeiss 2/50 makro, Samyang 8mm fisheye, Sigma 150 macro, 120-300 f/2.8 OS, Celestron 1325/13 Tinies: Sony HX9V.
