It is currently Wed Jun 19, 2013 11:49 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Sun Jan 24, 2010 6:37 pm
I'm about to purchase my first flash and I'm thinking about getting the 430 EX II, but I'm worried that I might end up regretting not buying it's bigger brother. Should I just spend the extra $20 and get the 580 EX II?
PostPosted: Sun Jan 24, 2010 8:09 pm
First off, the difference in price is $165 USD on B&H, not $20 (I think you meant to say $200).
Look at the differences. The 580ex II...
...is heavier
...is larger
...is more powerful - I have read that its 85% more powerful
...is weather sealed
...can turn 180degrees both left and right (430 is 180 to the left, 90 to the right)
...tilts -7 deg. to 90 deg. vertically (430 does not go -7)
...has a built-in catchlight card
...can be a wireless transmitter and a master controller
...has a wheel on the back instead of buttons
...has a socket for an external battery pack
...has an external metering sensor
...has a pc terminal
It costs more, but you get what you pay for. If I were you, I would definately get the 580ex II. Later on, you could always buy a 430ex II to use in addition or as a backup.
EDIT: I forgot to mention...the 580ex II has finer control. It can go from 1/1 power down to 1/128 in 1/3 increments. I believe that the 430 can only go to 1/64 power in 1 stop increments.
My Site
PostPosted: Sun Jan 24, 2010 8:20 pm
I had the same dilemma a few months back but decided to go safe and went for the 580EX II. In the end I didn't want to be "thinking what if I'd bought the 580Ex instead..."
Trust me you won't regret it.
Canon EOS 5D MK2, EF-24-105mm F/4L, EF-50mm F/1.2L, Speedlite 580EX II
http://www.flickr.com/photos/2ndtake/
PostPosted: Sun Jan 24, 2010 8:34 pm
Had the same problem but I ended up getting the 430EX II. I say both flashguns are very good. It was kinda tight for me financially so I took the 430EX II but no regrets. Its a very good flashgun & I think practically I don't need the features of the 580EX II (at the moment anyway...for my needs) and can always upgrade in the future...but that's me. Enjoy whichever you choose...you'll have fun using it.
PostPosted: Mon Jan 25, 2010 12:54 am
I went with the 580ex II for 3 reasons...
1) more powerful so better for outdoor wildlife shots requiring fill lighting.
2) has the capability of being a wireless transmitter for slave flashes.
3) weather sealing.
PostPosted: Mon Jan 25, 2010 1:38 pm
I went with the 430 myself-
My camera isn't weather sealed, power is adequate for my purposes at this time, wireless master is no use if I don't have a slave and if I get a 580 in the future I can still use my 430 as a fully ETTL slave.
I'd love to have the 580, but I would have been looking at another $200. I'm going to spend that extra $200 on some cheap RF flash triggers and a couple old manual flashes.
Canon 1000D, EF-S 17-85, EF-S 60mm macro f/2.8, EF 50mm f/1.8, Tamron 70-300, 430EX II
PostPosted: Mon Jan 25, 2010 3:53 pm
I also went with the 430EX (non-II). I am very pleased with it and have had zero issues with it.
I bought it before the 7D even existed but am happy I saved the $200 since the 7D has built in remote flash triggering. I could probably use the extra reach of the 580EX at times but that hasn't stopped me from getting good shots with my 430.
Canon 7D, Canon EF 24-105mm f/4L IS USM, Canon EF 70-200mm f/2.8L USM, Canon EF-S 10-22mm f/3.5-4.5 USM, Canon EF 50mm f/1.8 II, Canon Speedlite 430EX, Canon 7D Battery Grip, Canon 12mm Extension Tube.
PhotoBlog: http://www.ancker.net/photoblog/
Gallery: http://www.ancker.net/gallery/
PostPosted: Mon Jan 25, 2010 5:11 pm
430ex ii does this.
Mark Osborne
My life through an iPhone
PostPosted: Mon Jan 25, 2010 7:39 pm
I know a pro who's won more prizes than I have taken pictures, and he uses the nikon equivalent of the 430 EX II...so I think you're fine with it. It should be powerful enough, unless you want to kill ambient in full sunlight ;)
PostPosted: Tue Jan 26, 2010 2:31 am
Read a little bit of "The Hot Shoe Diaries" :!: (not porn) at books a million and after looking at some of the set-ups and results...well now I want both. :( . Why oh why couldn't I just have taken up rock collecting.
PostPosted: Tue Jan 26, 2010 2:57 am
Orsan Kart wrote:
430ex ii does this.
This is directly from Canon's site:
"The flash head can be moved up from 0 - 90° (5 settings), left from 0 - 180° (7 settings) and right from 0 - 90° (4 settings)"
Listed Here
Not that 7 degrees makes a big difference.
I'd also like to correct myself, the 430ex II does go from 1/1 to 1/64 in 1/3 stops, not 1 stop increments.
My Site
PostPosted: Tue Jan 26, 2010 4:10 am
Interesting after reading spawn's post. The 580 covers af points of 1, 3, 5, 7, 9, and 45. The 430s don't cover beyond 9 points. Also neither are matched for the new 7d's af points
Canon 7D/350D, Σ17-50/2.8, 18-55IS, 24-105/4 IS, Σ30/1.4, 50/1.8, 55-250IS, 60/2.8, 70-200/4 IS, 85/1.8, 580ex II, 430EX II, 270EX II.
PostPosted: Tue Jan 26, 2010 10:58 am
RHDxSPAWNx wrote:
Orsan Kart wrote:
430ex ii does this.
Listed Here
well my findings come direct from my flash, but canon has rehashed old settings by the looks of it :shock:
Mark Osborne
PostPosted: Wed Jan 27, 2010 8:10 am
Orsan Kart wrote:
RHDxSPAWNx wrote:
Orsan Kart wrote:
430ex ii does this.
Listed Here
This is incorrect...the 430ex ii does not go to -7 degrees. That's a only 580ex feature.
I also own the flash.
Also direct from the-digital-picture.com
"While the Canon Speedlite 430EX Flash head moves up/down from 0 to 90°, left from 0 to 180°, and right from 0 to 90°, the 580EX II allows an additional -7° down and a full 0-180° rotation right. While both flashes feature a pull-out/flip down wide angle diffuser to cover lenses out to 14mm (FOVCF equivalent), the 580EX II includes a white plastic pull-out catchlight reflector panel in addition. The Canon Speedlite 430EX Flash features 6 custom flash function settings, the 580EX II features 14. Instead of a dial for adjusting settings, the 430EX utilizes rounded parenthesis-shaped buttons. I can understand making buttons safe from accidental changes, but these buttons are narrow and require an excessively deep press to make changes. The dial is much easier to use. "
PostPosted: Wed Jan 27, 2010 5:13 pm
430ex here also. At first it was the price deference is why I went that way. Then I find myself rarely using it but when needed, it works just fine.
Canon 40D
Canon EF 24-70mm f/2.8L USM
Tamron AF 70-300 F/4-5.6
Canon Speedlite 430EX.
