It is currently Wed May 22, 2013 12:22 pm
PostPosted: Mon Jan 05, 2009 1:40 pm
Hello,
First post and first question.
I have a Nikon d80 and am thinking of buying the Sigma 10-20 mm lense. My question is will the Nikon Xd sensor increase the mm of the Sigma by 1.5 turning the 10-20 into a 15-30mm?
Thanks
PostPosted: Mon Jan 05, 2009 2:51 pm
In a nutshell, yes 8)
But remember that you are not gaining focal length, but instead gaining a view perspective of a 15-30mm lens attached to a full-frame DSLR.
Welcome to the labs and enjoy your stay :wink:
PostPosted: Mon Jan 05, 2009 3:25 pm
Hello Fantom Flasher, and welcome to the friendly Camera Labs forum!
As to your question: You will shoot images with the 10-20mm on a D80 like with a 15-30mm on a FF/FX/35mm-film-camera.
It is the widest lens that you can get for the D80!
PostPosted: Mon Jan 05, 2009 3:36 pm
Thanks guys,
The d80 and digital photography are a bit new to me and I read somewhere that the d80 will increase focal length on non XD lenses. So I thought that the d80 it will increase the Sigma from 10mm to 15 while I want to shoot at 10mm. So if I am getting this right you guys are saying that wont happen and I will still have 10mm.
PostPosted: Mon Jan 05, 2009 4:25 pm
Put simply:
A 10mm lens on a DX body (eg. D80) will be narrower (less of the scene appears on the sensor) than a 10mm lens on a FF/FX body (eg; Nikon D3)
i.e. More of the scene will appear on the sensor of the FF/FX body than on the DX body when using the same lens at the same focal length from the same shooting position.
Absolutely no focal range increase takes place... nada.
Hope that clears it up for you.
PostPosted: Mon Jan 05, 2009 7:02 pm
Thanks, that clears it up.
So this lense will be useless to me cause I want it to go wider instead of narrower.
PostPosted: Mon Jan 05, 2009 7:13 pm
Another question if you guys could please anwser. Would the same thing happen to the Sigma on a Sony Alpha 300?
PostPosted: Mon Jan 05, 2009 7:52 pm
Yep, and the Canon 40D/50D etc.
As long as it's a so called APS-C sensored body.
PostPosted: Mon Jan 05, 2009 8:16 pm
I really want to buy this lense. Should I accept this as a fact of life and this will happen on most cameras or is there anything I can do about it?
Thanks
PostPosted: Mon Jan 05, 2009 9:02 pm
as said before: 10mm is the widest lens you can get for any cropped frame sensor (leaving fisheye's aside). And every camera below ~3000$ WILL be a cropped frame ;) So yes: GET one, 10 (or 15mm Fullframe equivalent if you want) is really wide allreade!
Canon EOS 5D Mark II | Canon EF 35mm f/1.4L USM | Canon EF 85mm f/1.8 USM | Canon EF 135mm f/2L USM
...and a lot of lighting stuff. -> complete list of equipment
Website
Blog
PostPosted: Mon Jan 05, 2009 10:51 pm
Ok thanks guys, I finally used some of those gray cell in my noggin' and figured out how it works.
PostPosted: Tue Jan 06, 2009 1:42 pm
Fantom Flasher wrote:
Should I accept this as a fact of life...
Yup...
... In the world of photography, there's no such thing as a free lunch. You always have to sacrifice something to gain something when it comes to photography. Compromise, compromise, compromise. But that's the fun thing about photography.
Keep this in mind, and you'll stay sane :lol:
B.T.W - I'm really enjoying my Sigma 10-20mm. As long as you don't get a bad sample, you won't regret getting this lens.
PostPosted: Wed Jan 07, 2009 5:59 pm
Yep got the Sigma and it is great. I wrote above I have a D80 but I was considering getting it, but went for the Alpha 300 instead. Works great on the Alpha.
Here are a couple practice shots. Not too many cause it was too cold
http://picasaweb.google.com/tpanasiak/Alpha?authkey=f3XNYNEw4iw#5288595169611675394
PostPosted: Fri Jan 30, 2009 7:26 pm
Accept the fact the the widest is 15mm (1.5 cropped). Keeping in mind this is still slightly better than canon's aps-c which is 1.6 making it 16mm.
Why would you want to go wider? The distortion will exponentially worsten with cropped frames if you go wider.
Canon EOS 450d/XSi, BG-E5 Grip, 4 LP-E5 battery, Canon EF-S 17-55 F2.8 IS USM, B+W 77mm Pro1 MRC UV0 filter, Canon EF-S 10-22mm USM, HOYA 77mm HMC UV(C) Multi-Coated Filter THIN, Canon 580EX II,
http://www.flickr.com/photos/31510271@N05/
PostPosted: Fri Sep 04, 2009 8:04 am
I've been looking at getting the 10-20mm for my canon 40d, but i already have the kit 17-85mm, on a cropped body is the 2mm really worth me buying it, ie would i notice a big difference or should i save my money?
Joe
Canon 40D + BG-E2N Grip | 70-200mm f/4L USM | 50mm f/1.8 Mk II lens | 17-85mm IS USM lens | Canon 430EX II | Other bits
Portfolio
