It is currently Sun May 26, 2013 3:44 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Sep 23, 2007 10:21 pm
Hi Rei, thanks for the additional comparisons...
As Thomas mentioned though, there's what looks like some camera shake in a couple of them. It's not as simple as just using a tripod though. You'll also have to switch off any anti-shake systems as these can actually introduce motion to an image which is perfectly stationary - and you should also use a cable release or self-timer to ensure the shot is taken without touching (and potentially wobbling) the camera.
But even then, there's some really valuable stuff in your examples, which show the new DA* model is far superior to the previous lens. You must be pretty pleased with it! And thanks also for showing us your test shots.
PostPosted: Mon Sep 24, 2007 9:38 am
Hi Gordon and Tombomba,
Thank you for your feed-back. I really appreciate.
I looked closer at what happened,
  • The K10D was on a tripod,
  • The shake reduction was off,
  • The remote was used with a 3 seconds delay.
So what went wrong?
On portrait mode
I was shooting on portrait mode, so the K10D was on vertical position, attached to the tripod through the socket.
The problem is between the tripod and the K10D. The tripod screw should be very tightly secured into the K10D, otherwise the K10D could rotate due to the heavy lens. For the DA* lens, remember that the gravity centre is no longer located on the K10D but on the lens! So if the head of the tripod is not screwed very firmly into the K10D, it may rotate.
On landscape mode
The same problem may occur in landscape shooting, this time not between the tripod head and the K10D, but at the tripod vertical control that should secured very tightly. Otherwise, the lens could plunge!
EDIT More on this here with pictures!
More collateral damage
Page 62 of the K10D manual stipulates:
Quote:
When using a telephoto lens, a tripod that is heavier than the total weight of the camera and the lens is recommended to avoid camera shake.
Since the K10D + 50-135mm averages 2 kg / 4.4 lb, does that mean that a 2 kg / 4.4 lb tripod is required?
As another collateral damage (the fisrt one was a bigger bag), a solid and 2 kg / 4.4 lb capable tripod is strongly recommended.
--- rei_vilo
reivilophotography.weebly.com
PostPosted: Mon Sep 24, 2007 5:57 pm
This is why you see some photographers hang sandbags on the center-column of their tripods... :idea:
Beware: Your tripod has to be stable enough to carry this additional weight
PostPosted: Wed Sep 26, 2007 5:51 pm
Great review! This lens really looks good compared to the 50-200, better colors and sharper, and bokeh also looks very good. Will you also be testing the weathersealing :wink:
With a 2x teleconverter this seems like a very good lens. Could be nice to see this configuration in use.
Minolta primes: 2.8/20 2.8/24 1.7/50 2.8/135
Minolta zooms: 28-135 35-70 70-210(beercan) kit
Minolta cameras: Dynax 5D 7000
M42: Pentax Asahi S-M-C Takumar 1.4/50 and 2.8/105 Carl Zeiss Jena Flektogon 2.4/35 Industar-61L/Z Kiron 2.8/105 Macro
 Post subject: More details!
PostPosted: Fri Sep 28, 2007 8:15 pm
Bonsoir,
Here are more details on the DA* 50-135mm.
The lens connectors
We see: 1 more connector on the outer metal ring and 2 more connectors on the inner dark ring. The screw head for focusing remains in the DA*.
The front cap
Left, the DA front cap; right, the DA* front cap, easier to handle.
DA* and DA at 50mm
DA* and DA at 135mm
The DA* doesn't move! By the way, I realize how compact the DA 50-200mm is.
I apologize for the quality of the pictures: they weren't taken with a K10D and a DA* lens :lol:
--- rei_vilo
PostPosted: Fri Sep 28, 2007 8:18 pm
Here are some pictures to ease the explanation (and I guess, the understanding) of the tripod problem, due to the heavy weight of the DA* lens and center of gravity placed on the lens, far from the K10D.
For a landscape picture
The solid red dot shows the center of gravity while the red circle shows the pivot.
For a portrait picture
Same as before, the solid red dot shows the center of gravity while the red circle shows the pivot. I added a red line for the rear of the K10D.
--- rei_vilo
PostPosted: Sun Dec 02, 2007 5:02 pm
I took another batch of pictures of the cathedral of Chartres with the DA* 50-135mm, before testing the :arrow: DA* 16-50mm.
I really like how the light is playing with and captured by the stones of the cathedral.
1/180 f4 108mm ISO 100
The wonderful color of tainted glass.
1/30 f2.8 65mm ISO 1600
You could find other pictures of the cathedral of Chartres :arrow: here.
--- rei_vilo
PostPosted: Tue Jan 01, 2008 9:47 pm
Another Example of Depth of Field
1/125 f2.8 ISO 100 123mm
with the AF-540FGZ flash used in wireless remote mode
Detail with 600 x 600 center crop: it's sharp :!:
Well, to be honest, this is one nice shot out of a series of ten :)
However, it was worth the fun, playing with the location of the flash.
--- rei_vilo
PostPosted: Tue Jan 01, 2008 11:24 pm
I really like the piano shot...
Fantastic depth of field. Nice work!!!
PostPosted: Thu Jan 03, 2008 8:11 pm
Thanks, Markh :)
--- rei_vilo
PostPosted: Fri Jan 04, 2008 7:44 pm
Bonsoir,
On my review, I wrote
Quote:
Wrap-up
  • But this comes at a price, in term of weight and size, which may imply a learning curve, and also a stronger bag :).
So I went for a stronger (and bigger) bag :D
Please find my :arrow: Lowepro Rezo 190 AW Camera Bag User Review.
Enjoy :!:
--- rei_vilo
PostPosted: Sun Sep 21, 2008 9:10 am
Bonjour,
Here are two picture of :arrow: The Wave Sequence, shot this summer with the burst mode at high speed 1/3000.
Another example of the amazing quality of this lens :)
--- rei_vilo
PostPosted: Fri Apr 24, 2009 9:27 pm
There's a new comer to the lens family :!:
See my :arrow: Pentax smc DA* 60-250mm f/4 ED (IF) SDM User Review :)
--- rei_vilo
PostPosted: Thu Jun 25, 2009 1:33 pm
Bonjour,
See how this lens performs on bokeh compared with other DA* lenses.
Please check my :arrow: Pentax DA* Lenses Bokeh User Review.
--- rei_vilo
PostPosted: Thu Nov 19, 2009 2:04 pm
Bonjour,
An edited version of this user review is available on my :arrow: website.
Enjoy :)
--- rei_vilo
