1- First hands-on
The SMC DA* 50-135mm F2.8 ED [IF] SDM is an impressive piece of manufacturing. It's heavy, dense, solid.
What a name! This lens is packed with so much technology!
SMC = super multi coating
ED = Extra-low Dispersion
IF = Internal Focus
SDM = Supersonic Direct-drive Motor
The lens comes with a rear cap, a front cap (of a new and better kind, with inner handling), a hood and a soft case.
A first ring is for zooming, the second for manual focus. Both rings are large and comfortable.
Due to its heavyness, the 50-135 requires great care when fixing and unfixing it to the K10D. That's not easy, since the fixed part between the two ring is not very large. The usual
orange dot is here.
When fixed, the center of gravity is no longer on the K10D, but on the lens.
One big feature is that the lens moves inside and stays with the same dimensions outside. No more endless zoom as before!
A dedicated button switches the auto-focus on and off and is logically connected with the AF selector on the K10D (continuous, single, off). Once again, Pentax ergonomics are great.
SDM motor is quiet and fast. Actually so quiet that I strongly recommend to set the bip on for focus, through MENU > Preferences > Sound > Focus.
A small windows gives the distance in metric and imperial units.
All this comes at a price. The weight of the K10D and the 50-135mm combined reaches 1,5 kg / 3,3 lb. Because the center of gravity is on the lens, operating the camera with one hand is not that easy. You may use both hands or, better, you may require the BG2 grip, pushing the weight up to 2 kg / 4,4 lb! Another consequence is the need of a stronger bag.
Needless to remind that K10D firmware needs to be updated to 1.30.
Enough words: to the pictures now
--- rei_vilo
reivilophotography.weebly.com
