It is currently Sat May 25, 2013 2:53 am
 Post subject: Kata DR 461 backpack
PostPosted: Thu Dec 11, 2008 6:49 pm
This is a small backpack type camera bag. It seems intended to carry selected camera bits and little more. If you want an "everything" bag, this isn't it. The small size makes it more suitable for short to medium length trips where a smaller shoulder bag might not have the capacity, but a bigger bag would be too much.
Sticking to the outside, here are the two straps which I find decent to hold the bag stable. If you need more, there is a buckle across the chest you can also use. A loop is present on the top you can use to hand carry the pack. There is a stretchable pocket on the outside you can cram something long/thin in.
Inside the main compartment are various dividers held in place by velcro. There is a reasonable amount of padding between the inside and outside. Here you can see a Canon 50D with 100-400L lens fitted. The bigger lens to the side is the Tamron 18-270, and a 50mm f/1.8 in the other side. Also I've thrown in a Sigma 1.4x TC and a Kenko 2x TC. By rearranging the dividers you could easily put a standard external flash there instead.
There is a further internal storage compartment which can be accessed by both the outside front of the bag and also by an internal zip. This compartment, as pictured, does not have much height. So you can only put thin/flat objects in here. There are various pockets inside. I use this for filters, adapters, battery, CF cards etc.
My verdict, if you want to carry a moderate amount without getting weighed down, this is worth considering. I would like a little more depth in the thin compartment, but that would obviously make the bag much bigger.
PostPosted: Thu Dec 11, 2008 10:10 pm
Nice bag -- thanks for the review and pics.
How do you think the quality compares to LowePro? I am a fan of LP's product line -- and own two bags of theirs, but am always looking for other options.
PostPosted: Thu Dec 11, 2008 11:07 pm
I only have experience of one Lowepro bag, reviewed here. I'd say they're of comparable quality.
Forgot to mention in the above review of the Kata, it comes with a detachable waterproof cover. I think I lost it already...
PostPosted: Fri Dec 12, 2008 7:05 am
Nice Review!
Even Nicer Lens! :wink:
Tamron 17-50mm F2.8
Tamron 70-300mm F4-5.6
Sony F58
