It is currently Mon May 20, 2013 5:13 am
 Post subject: Gull sequence
PostPosted: Mon Dec 01, 2008 11:24 pm
There's no way I can post it in full here without everyone having stupidly wide monitors. Click above pic to visit my dA where the full version can be downloaded (4910x768, 1MB)
I made use of the sunlight while it was here today. Set the 50D to high speed continuous, stuck the 100-400L on the front fully extended and started my arm workout.
Settings for this was Tv mode at 1/800s and -2/3EV as the Gulls tend to white out against the background. Lens on IS mode 2 although I'm not sure if that was needed at all given the shutter speed. If I could do it again, I would go to -1 EV and knock the shutter down to 1/1000 as I still lost some highlights and I think that's motion blur on the wingtips.
Initial stitch done by Photoshop Elements with tidy up in Paint Shop Pro 7.
PostPosted: Tue Dec 02, 2008 4:54 pm
looks great 8) i need to try continous shooting out some time
Nikon D90 / 55 - 200 VR / 50 - f1.8 / tammy 90 / SB - 400
PostPosted: Tue Dec 02, 2008 5:25 pm
That's NICE, Popo! Looking good!
Have you tried to do that with Highlight Priority? It could help you keeping the highlights on the gull at the cost of a little detail lose in the background. It may be worthy :wink:
Canon 40D and lots of lenses.
my Flickr
PostPosted: Tue Dec 02, 2008 6:56 pm
If I understand highlight priority correctly, all it does is underexpose and compensate for the brightness, which is effectively what I'm doing semi-manually...
PostPosted: Sun Feb 08, 2009 7:41 am
It underexposes selectively. It's like the Shadows/Highlights tool in PSE. Tweaking the shadows slider will lighten the shadows but will leave midtones and highlights alone. Darkening highlights will affect only highlights.
PhilipGoh.com
PostPosted: Sun Feb 08, 2009 9:18 am
It has to underexpose everything, as the sensor would be set as a whole. In the software part the selective adjustment made to bring the exposure back to nominal for mapping. As cautioned in the manual, this may result in a loss of shadow detail.
I did play with the highlight priority setting a little another time, but don't use it now. It wont let you select high ISO settings while it is active.
Also, in PSE turning up the lighten shadows slider can darken the shadows too! But the only times I've seen that have been in bright low contrast images. They might be better calling the function shadow correction as opposed to simple lightening. Note this is only the shadow slider, with no contribution from the highlight slider at all.
PostPosted: Sun Feb 08, 2009 10:39 am
Looks awesome to me as is Popo.
Great job!
Pentax K-5
PostPosted: Sun Feb 08, 2009 8:36 pm
Thanks for the info popo. I always thought that DRO was done in software (i..e the Bionz whatever) and didn't affect the originally exposed image in any way.
PhilipGoh.com
