It is currently Sun May 19, 2013 8:51 am
PostPosted: Thu Nov 20, 2008 5:53 pm
I tried a similar closeup lens on my a200 but for some reason it wouldnt focus at any distance on AF mode.The closeup lens was from another brand though.But still I dont know why it could not focus. I would really like to give this a try before I start saving for 1:1 macro lens.
Canon 40D w/vertical grip
Sigma 24-70mm EX DG f2.8
Canon EF 300mm f2.8 L USM
Canon 400mm f5.6 L USM
San Disk Ultra II 4gb
Manfrotto 681B
Canon 200 EG backpack.
PostPosted: Thu Nov 20, 2008 5:57 pm
I think they'll all work similarly. The closeup lenses tends to significantly reduce the focus distance range. If you're not in the new focusing range then it wont work. There may also be a near limit to how close the AF works, as there are many lenses which will only AF beyond a certain distance.
PostPosted: Thu Jan 08, 2009 11:45 pm
Following on from another thread, here's some pics of the Sigma 150mm macro lens, with and without Sigma 1.4x TC, with and without the "macro" closeup lens on front. Note the closeup lens I have is 62mm in size and the Sigma takes 72mm size. I used a step down adapter ring to fit it. All photos taken at minimum focus distance (manual). I focused where the lines cross below the "80" on the ruler.
Lens only, f/5.6, approx 1.0x magnification. Ignore the glow at the bottom, that's an out of focus area of the base I was resting the ruler on.
Lens + 1.4x TC, f/5.6, approx 1.44x magnification
Lens + 1.4x TC + closeup, f/5.6, 3.38x magnification
Lens + closeup, f/8, 2.44x magnification
All shots were at ISO800, aperture priority. I reduced the aperture for the last one as past experience showed it helps reduce the glow from the closeup lens, but I didn't go back to do it on the earlier shot with everything.
