It is currently Wed May 22, 2013 1:30 pm
PostPosted: Fri Sep 05, 2008 1:35 am
When I'm downoading pictures with my card reader I'm having some speed issues. The fact is, that some times it downloads quickly at about 20mb/s, and sometimes it is only capable of reaching about 2mb/s.. Anyone with similar problem or suggestions?
Canon 40D | Canon EF 24-105mm f/4L IS USM | Canon EF 50mm f1.8 II | Sigma 10-20mm f/4-5.6 EX DC HSM | Canon BG-E2N | Canon Speedlite 580EXII |
PostPosted: Fri Sep 05, 2008 5:31 am
usually if you are connected via high speed reader, its always high speed.
the only way this would make sense is if your computer was already working hard, such as, if you were downloading something playing music ripping a cd and ten other things while trying to upload photos
D60 - SB-600
18-55VR
50mm f/1.8
90mm f/2.8
PostPosted: Fri Sep 05, 2008 10:04 am
Is it a USB card reader? USB is dependent on the CPU so when you are performing other tasks, your transfer rates will drop.
Graham
PostPosted: Fri Sep 05, 2008 1:27 pm
It is a USB card reader, but as far as I van tell, it has nothing to do with my cpu. Sometimes I'm only running fireox, and with a dual core 2X2.4ghz it should be fast. Could it be the fact that it is a cheap reader?
PostPosted: Sat Sep 06, 2008 4:36 am
Could be.....how are the speeds when doing nothing at all?
Graham
PostPosted: Sat Sep 06, 2008 5:22 am
Inconsistent, sometimes fast, sometimes not. Wierd...
PostPosted: Sat Sep 06, 2008 8:45 am
I have had a Belkin USB card reader for nearly 2 years now works at the same rate all of the time, suggest you try another reader.
Roy
My Fotopic :-)
PostPosted: Tue Oct 14, 2008 11:55 pm
Have you tried a different cable? That was the problem I had with a low quality cable!
Paul
http://worldofphotos.proboards52.com
http://paulbednall.blogspot.com
http://www.myspace.com/bednallphotoandfilm
http://www.flickr.com/photos/thribb
PostPosted: Fri Oct 17, 2008 3:54 pm
It can be that your memory card has bad clusters, and that is very possible. Copy your images on your PC and then give the MC a full format. After that, scan it for any errors using scan disk. If this doesn't help then it could be that your USB port doesn't have constant voltage, this is because of mother board or power supply failure...and wrong BIOS settings
PostPosted: Sat Oct 18, 2008 4:43 am
Well, I don't think it's bad clusters, since I changed to this:
I've only have the speed slowed down once a twice over a two month period, something I can handle. Generally, my download speed is between 20and30mb/s now, so I'm very happy!
