It is currently Sun May 26, 2013 2:22 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu May 22, 2008 8:39 am
I'm sure the A700 could be tweaked to give similar results...
PostPosted: Thu May 22, 2008 8:35 pm
hi guys,
prices just went down on the k20D, via a $100 rebate plus an across the board $50 price decrease. they read the review.
canon has been pushing the 40D prices downwards too though, and the kit with the IS lens is only about a hundred more than the body only.
alfredo
PostPosted: Thu Jul 10, 2008 11:18 pm
The Samsung GX-20 would has some different than K20D in image quality??
Some rumors say Samsung would be develop a new FF sensor, this will be interesting...
Samsung NX100
18-55mm f/3.5-5.6 OIS
iFn 20-50mm f/3.5-5.6 ED
iFn 20mm f/2.8 (coming soon)
30mm f/2
50-200mm f/4-5.6 ED OIS
Sony VAIO CR140F White
PostPosted: Fri Jul 11, 2008 12:02 am
How can the quality be different if it's the same sensor? (Samsung branded)
Visit my work here
PostPosted: Fri Jul 11, 2008 1:43 am
Hi Razvan, the final image is not just about the sensor but also the image processing. But before you ask, I can't comment on the GX-20 as I've not tested it!
It's good to see some cheaper prices on the K20D though...
PostPosted: Fri Jul 11, 2008 4:16 am
Samsung use a different procesor for JPEG and use DNG instead of RAW.
The GX-20 with kit lens is about 20% less than K20D only body.
Samsung NX100
30mm f/2
PostPosted: Sun Jul 13, 2008 6:17 pm
The only difference ive noticed on the GX20 was the menus interface, its more sofisticated but i liked the feel of pentax's body though...
One thing i have to say about the K20D's AF is that it resumes to accuracy, it might be sometimes slower than rivals - lets say Canon 40D- but its more accurate because it double checks it, so its a matter of choise, if your into professional jobs like photojournalism you would probably go with faster focus (if you play close attention many pictures you see in newspapper and magazines are OOF), but if your more into an artistic area you should go with Accuracy
PostPosted: Sun Jul 13, 2008 6:53 pm
I would like prove the GX.20 with 12-24mm f/4... :)
Samsung NX100
30mm f/2
