It is currently Tue Jun 18, 2013 6:33 am
Post new topic Reply to topic  [ 129 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
PostPosted: Wed Jul 18, 2007 9:49 pm
Great, here I go... :arrow:
--- rei_vilo
reivilophotography.weebly.com
PostPosted: Sat Jul 28, 2007 4:24 am
me again
so after almost 3 weeks now ive snapped 1500 photos so far
one thing that ive noticed is :
when im taking photos of whatever and there is a tree in the back ground im getting a purple haze around some of the leaves . how do i correct that?
also im LOVING when i do get "the perfect picture" but to be honest im at about a 20% satisfaction right now with my photos ( i suck not the cameras fault)
im learning to adjust everything right now im just staying in P for now till i somewhat master that then ill move to the next and so on and so on
here is a pic i took today of my goat george that just came out AMAZING i thought
http://img.photobucket.com/albums/v280/ ... GP1350.jpg
Live music is the best
www.myspace.com/death2man666
www.myspace.com/drillband
http://www.flickr.com/photos/9684309@N06/sets/
PostPosted: Sat Jul 28, 2007 7:27 am
Hi Drill, nice photo of George!
The purple fringing you're seeing is due to a combination of chromatic aberations in the lens and sensor blooming, where there's too much difference in contrast for the sensor to handle.
There's not a lot you can do about the latter, but the former is caused by lenses which aren't perfect. Before you get concerned, it affects most lenses, but some have it worse than others. It's generally worse towards the corners and at open apertures (small f numbers).
You'll see it in high contrast areas, so anywhere the subject suddenly goes from very bright to very dark. Trees and rooftops against a white overcast sky are the most common examples.
Short of buying a top of the range lens to avoid chromatic aberations, you can actually get rid of it quite effectively in programs like Photoshop. Basically you desaturate the offending area, thereby removing the unwanted colour. Photoshop allows you to be quite specific about this, only desaturating certain colours in certain areas. If people are interested, I can post a workshop in the future...
PostPosted: Sat Jul 28, 2007 7:46 am
i dont have photshop and kinda broke since now im saving up for a brand new John deere tractor now hahah
DAMN MY EXPENSIVE HOBBIES!!!!!!!!!
i do have Corel Photo-Paint 7 (copy from a freind , all i know how to do on it is , brighten or darken the light levels other than that its kind of tricky
and yes any videos that will help me on my way of being a better photographer im all for it , SOOO MORE VIDEOS!!!!!!!!
PostPosted: Sat Jul 28, 2007 7:48 am
You should be able to do it in Corel - find the saturation option - this adjusts the amount of colour, so if you turn it all the way down, it'll basically make it black and white. So just select the areas with the purple in them and turn the saturation down to make it more discreet.
I'll post a proper workshop in the Imaging section in the future!
PostPosted: Sat Jul 28, 2007 8:20 am
you the man Gordon ............ YOU THE MAN!
PostPosted: Sat Jul 28, 2007 9:45 am
Bonjour Drill-lights,
Two tricks that might help you :!:
First trick: use image crop as an alternative to zoom
Instead of using full zoom (i.e. 200mm on your K10D), try a lower value (e.g. 100mm) with less chromatic aberration, take the picture and then crop part of the image.
The 10 M pixels give you plenty of details: so picking 6 M or even 3 M out of the 10 M image is not a problem. I gave an example with the bird :arrow: http://www.cameralabs.com/forum/viewtopic.php?p=3559#3559
By the way, which zoom are you using :?:
Second trick: use RAW file and Pentax Laboratory
If you shoot in RAW mode, you can process that image with the Pentax Laboratory software, bundled with the K10D. Pentax Laboratory software is pretty exhaustive and can address chromatic aberration.
Event better, if you're using a Pentax lens, let say, the 50-200mm zoom is registered in the Pentax Laboratory software, so image improvement is easier since parameters are known by the software.
Enjoy and keep discovering :!:
--- rei_vilo
PostPosted: Sat Jul 28, 2007 4:08 pm
one thing about RAW is , i ALWAYS forget about it when im taking photos . i have my mind so wrapped up on trying to get everything else correct that i just forget about it
but ill try to remember next time
my farm house is getting torn down soon and we are rebuilding HOPEFULLY i can remember to shoot in raw that day
PostPosted: Sat Jul 28, 2007 5:39 pm
Drill-lights,
To shoot in RAW, two options:
  1. Press the special RAW button on the left of the camera. This is valid for one shot only.
  2. Select the RAW on the MENU > Capture parameters > Page 2/2 > Line 1 File Format > RAW or RAW+. RAW+ give you RAW+JPEG.
Up to you to pick the most convenient for you :!:
--- rei_vilo
PostPosted: Sat Jul 28, 2007 8:27 pm
This to me is the primary benefit of shooting in RAW. Once you have it set you can forget about it and get on with the more important elements such as composition and lighting.
Zorro.
PostPosted: Sat Jul 28, 2007 10:50 pm
One thing that seems to reduce the amount of PF is using a smaller aperture (use f/8 or f/11 rather than f/5.6 or larger). Of course, this also increases the DOF and reduces the shutter speed....
Darrin
Nikon D40 | Nikkor 18-55 VR | Nikkor 55-200 VR | Voigtländer Ultron 40mm SL-II | Nikon Speedlight SB-400
PostPosted: Mon Aug 06, 2007 3:46 pm
This forum really helped me decide on the K10D, especially this post by rei vilo. Here are my thoughts about the camera after 3-day use which I had originally posted in Future K10D Owner.
As I get more familiar with the K10D, I will add to this post.
I'm very happy with my new camera and I don't regret going with Pentax. I can't really do a review because I'm still learning how to use the d-slr (I wasn't even using AF when I was shooting film).
I'm very impressed with the noise when shooting at 1600ISO which was something that worried me (from what I saw in some digital P+S). In the K10D, it's very soft and appealing to me.
The DA*50-135 f2.8 is a fabulous lens as well. Once you update the firmware (v.1.30), it's almost silent! It really makes a difference. I think it's pretty quick but as I've said I never really used AF before.
The images are quite crisp and it works wonders even in very dark situations. If you look in my photo gallery (I'm also learning how to use Aperture), the first 3 images were taken in a room where the shutters were closed "à l'espagnol" so there was very little natural light coming into the room.
Many reviews state that the K10D is very heavy so I suppose I was expecting a beast. Not so! Everything is relative of course. Compared to my Nikon F90x, the K10D is lightweight! ^.^ Of course when you attach the 50-135 it's much heavier but again, I was expecting much worse. I do notice though that I tend to tilt to the left so perhaps I really should consider buying a monopod for when I go outside.
I'm still in the learning process concerning the different exposure modes so it would be unfair for me to say anything about them. Overall, I've been happy with the exposure metering (especially since I've been shooting in darkish environment).
http://homepage.mac.com/cherrylicious/K10D-DAstar50-135/
PostPosted: Mon Aug 06, 2007 8:13 pm
Great, I think we are going to launch a French K10D thread :)
--- rei_vilo
PostPosted: Sun Aug 19, 2007 3:40 pm
Please find my review of the book Pentax K10D - Magic Lantern Guide, by Peter K. Burian as well as 3 others books
at :arrow: http://www.cameralabs.com/forum/viewtopic.php?p=6865#6865
--- rei_vilo
PostPosted: Sat Aug 25, 2007 3:37 pm
When I reviewed the Pentax Remote Assistant (see :arrow: http://www.cameralabs.com/forum/viewtopic.php?p=3888#3888), I complained about the small viewfinder screen offered.
Playing again with the software, I've found how to obtain a bigger viewfinder screen: use the menu View > Separate screen display.
Despite being larger, the viewfinder screen is not that big and remains too small for checking precise focusing.
One solution is to keep the directory where pictures are saved ready and to use Preview to have a closer look.
--- rei_vilo
