It is currently Mon May 20, 2013 3:04 am
 Post subject: Canon Xti Lens
PostPosted: Fri Nov 17, 2006 6:30 pm
Good Evening
I've purchased the Xti body only, now I am looking at lens', not looking for anything too fancy, good standard lens for about 200max$
what kind of lens are my option ?
p.s Payed 700$ canadian for Xti body.
thank you
bye.
PostPosted: Fri Nov 17, 2006 8:26 pm
Hi Jimmy, I'm a bit surprised you didn't go for the kit as discussed on the other thread - the Canon 18-55mm aint perfect by a long stretch, but it sure is the cheapest general purpose lens around when bought as a package.
Anyway, if you've gone for the body alone, and are after a budget general purpose lens, you should consider some models by Sigma and Tamron. That'd be a good starting point, but 200 CDN is going to be tough... I think you'll be limited to one of their 18-50mm lenses for that price. Or you could look on ebay for the Canon 18-55mm.
PostPosted: Fri Nov 17, 2006 8:28 pm
PS - you could of course alternatively buy a 2nd hand Canon lens, and some EF models will be very cheap, but they may not be that wide on your camera - remember DSLRs like the XTi reduce the field of view by 1.6x, so if you were to pick up a cheap, say, 28-80mm, it would perform like a 45-128mm.
So if you want wide angle on your XTi, you'll need a lens which starts at around 18mm.
PostPosted: Sat Nov 18, 2006 5:41 am
thank you so much for the info sir !
I will get a used kit lens for the xti/xt model, Its best I start at the basics and go on from there, its the right move for a rooke DSLR owner.
