It is currently Wed Jun 19, 2013 12:00 pm
Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon May 12, 2008 10:37 am
If you merge to HDR in CS3 you shouldn't have to do it again in Photomatix, merging to HDR in one or the other should be sufficient. If you do it in Photomatix however, the image that you are presented with after the merge is not the final image. You have to tone map it first.
Graham
PostPosted: Mon May 12, 2008 3:14 pm
Location: Currently in Ghent, Belgium but from Cebu City, Philippines
Yes, that is what i did. I want to merge into a HDR using CS3 and use only photomatix for tone mapping. I saved the HDR from CS3 into a tiff file. I then open it in photomatix but all i see is black when i open it. what am i missing? thanks for the reply... :)
PostPosted: Mon May 12, 2008 4:09 pm
What happens if you do the merge within Photomatix? Does that work out? And why use Photoshop for HDR anyway? In my limited experience PS is pants at HDR.
Zorro 8)
PostPosted: Tue May 13, 2008 4:04 am
Yeah, you're right. I was tried to follow a tutorial in youtube. He merged the different exposures in PS and saved it into a tiff file. He then loaded the tiff files in photomatix for tone mapping.
Anyway, I tried what he taught but all I get is a blank screen well I load it in photomatix. I was just curious on why it wouldn't work. I use photomatix for everything anyway. Thanks for the reply!
Fritz :)
PostPosted: Thu May 15, 2008 10:55 am
Hello again!
How do you minimize noise in your HDR images?? :)
Fritz
PostPosted: Thu May 15, 2008 11:35 am
I put the images through noise-ninja after Photomatix is done with them. Playing around with the various settings and sliders in Photomatix also helps but this would vary from image to image.
Graham
PostPosted: Thu May 15, 2008 4:36 pm
Just popped in to make a quick apology for not responding to people from back in February. I'm glad this tutorial and all the others available out there are helping people.
Alex, judging from the photos I've seen from you lately, you've obviously got HDR all sussed out now :)
Mark Amy Photography
PostPosted: Mon Jun 02, 2008 11:45 am
This is great, thanks Mark.
I've always tried to do HDR but the tone mapping procedure was just the hard part for me, i guess i have to experiment a bit more.
Sony Alpha A200
Minolta 50 f1.7
Minolta 17-35mm f2.8
Sigma 55-200
Helios 58 f2
Tair 11A 135mm f2.8
Minolta 35-70 f3.5-4.5
DT 18-70 Kit Lens
Soligor Macro Tubes
San Disk Compact Flash Ultra II 4 GB and 2G
Lawepro Slingshot 300AW
PostPosted: Wed Jun 04, 2008 12:00 am
Hey Mark,
Great tutorial, I'm going to have a good read and use that later! Question regarding the three different shots. You've suggested changing the shutter speed, elsewhere I've read that you can use exposure bracketing. Will there be much difference in the images by using either technique?
PostPosted: Wed Jun 04, 2008 4:14 am
Welly wrote:
Hey Mark,
you could just use one image and copy paste is a couple times on your comp. and digitally change the exposers to merge them...or is that bracketing...idk. thats usually what i do though
D60 - SB-600
18-55VR
50mm f/1.8
90mm f/2.8
PostPosted: Wed Jun 04, 2008 4:35 am
Welly wrote:
Hey Mark,
Hi Welly,
No difference. Exposure bracketing automatically changes the shutter speed as long as you take the bracketed pics in Aperture Priority so the depth of field & focus doesn't change. Remember to keep the same, low ISO too. If you leave it on Auto it could increase on the under-exposure and you want to keep it as low as possible on all pics to keep the noise levels down.
Good luck, look forward to seeing your results.
PostPosted: Fri Jun 06, 2008 12:39 am
wow...what a great tutorial...ever since i've been on this forum, HDR photography realllly caught my interest...now all i need is a DSLR to take pics! :cry: ...
PostPosted: Fri Jun 06, 2008 2:46 pm
Hey there, haven't posted here in absolutely ages!
I'm having a bit of trouble with merging HDR's in photoshop, well not the merging bit anyway.
I want to convert them into black and white after the process and my usual way is
Layer > New Adjustment Layer > Black & White.
However after the merging the image seems to be locked and I can't do anything major to it, I'm confused! If anyone can shed any light on it I woul be very grateful.
Using: Canon EOS 400D, EFS 18-55mm, Tamron DI2 55-200mm
PostPosted: Tue Nov 04, 2008 3:04 am
Awesome tutorial!
Finally, i've been looking for a HDR-how-to...
Thanks and nice shots btw..
Tamron 17-50mm F2.8
Tamron 70-300mm F4-5.6
Sony F58
PostPosted: Tue Nov 11, 2008 12:54 am
this is my atempt..
these were taken at 11pm tonight with the moon the ONLY source of light, im amazed the camera can find light i cant see with my own eyes!
outcome......
Amateur, always learning!
