It is currently Sat May 25, 2013 11:47 pm
PostPosted: Mon Jun 25, 2007 10:42 pm
Being occasionally a little slow on the uptake I have only just realised that neither Canon nor Nikon make a fisheye lens for their cropped sensor models. OK, their fisheye lenses will work on the 400D/D80 etc. but they won't give the 180° diagonal view which rather defeats the objective (sic).
Don't such cameras deserve proper fisheye lenses?
PostPosted: Tue Jun 26, 2007 2:08 am
Hmmm - the 10.5mm f/2.8G ED AF DX Fisheye-Nikkor claims 180 degrees...
Check the user review posted by Thomas here: http://www.cameralabs.com/forum/viewtopic.php?t=248&highlight=
Darrin
Nikon D40 | Nikkor 18-55 VR | Nikkor 55-200 VR | Voigtländer Ultron 40mm SL-II | Nikon Speedlight SB-400
PostPosted: Tue Jun 26, 2007 8:12 am
I confess I am not terribly clued up about Nikon name conventions but are you saying that this lens can only be used with Nikon's cropped sensor models? If it is designed to work with their full frame camera bodies then as it gives a 180° diagonal view with them it can't give the same coverage with a D80. In my book that disqualifies it from full fisheye status with such cameras even though it does provide some barrel distortion.
PostPosted: Tue Jun 26, 2007 8:59 am
Hi Bob, DX in Nikon's naming convention means it ONLY works on cropped bodies. But as you know, Thomas is the expert on this lens, so over to his review!
PostPosted: Wed Jun 27, 2007 6:23 pm
Yep, Gordon is rrrrright!
DX means it's 180° on cropped sensors. On a FF-body the 10.5 produces a circular picture.
 Post subject: One up to Nikon
PostPosted: Thu Jun 28, 2007 3:14 pm
Thanks Gordon, thanks Tom.
Nikon definitely wins this round as the Canon EF 15mm f2.8 Fisheye is designed for full frame sensors and so may not provide the expected effect on cropped sensor bodies.
