It is currently Mon Jan 23, 2017 9:47 pm
PostPosted: Tue Jun 12, 2007 11:47 pm
Alright, so this is my first prime lens. On my Xti body it is an equivalent of 80mm.
The first thing I discovered with prime is optical quality. It produces images so sharp and really capture the right colors.
Sure, it's not easy to attend a car show - you have to be at 20 feet from the car.. but the image quality is absolutely stunning.
Construction: 3/5
Plastic feel. Seems fragile. Tiny Manual Focus Ring.
Features: 3.5/5
Well it's a prime lens. Struck at 80mm. Good for portraits and low light, but not easy to use as an all-around lens
Image Quality: 5/5
Amazing! Really sharp, and the colors are really great.
Ease Of Use: 4/5
Easy to use, but sometimes requires to be at 10-15-20 feet from the subject.
Value For Money: 5/5
Worth every penny and more, the image quality is amazing.
PostPosted: Tue Jun 12, 2007 11:49 pm
Thanks Cr4zYH3aD! Have you used it much in low light conditions?
PostPosted: Wed Jun 13, 2007 8:12 pm
Is it possible to get a sample shot on different apertures? How is the bokeh wide open?
This would be my first lens if I went Canon.
PostPosted: Wed Jun 13, 2007 8:28 pm
here's some pictures that I took with it
Details and sharpness !!!!:
 Post subject: comparison
PostPosted: Mon Jun 18, 2007 7:46 pm
what would be more interesting is a comparison like the ones Gordon has.. two different lenses at the same settings.
in this case, since you have reviewed and have access to both the kit lens[ 18-55] and this prime lens.
can you set up a picture such that the kit lens is zoomed in to 50mm focus and both set at the same aperture? [ except where in applicable .the kit cant go to 2.8 ]
also what is the best range ? i find that the kit lens is best at around an F stop of between 5-8 and zoomed into about 30 mm.
I absolutely dislike the small plasticy focus ring on the kit lens.. not comfortable at all.
PostPosted: Fri Jun 29, 2007 7:44 am
Hi Gordon, have you had any experience with this lens?
PostPosted: Fri Jun 29, 2007 8:35 am
Yep, I've used it for some resolution tests in the 10 Mpixel group test. It was pretty good quality, and the f1.8 aperture is really useful in low light. It's a handy lens to have and the only affordable one with a fast aperture!
PostPosted: Fri Jul 04, 2008 7:24 pm
Nothing elegant here but just a aperture comparison. All shots at ISO 100, WB - Shade, with the 50/1.8 on a tripod. I didn't use mirror lockup which would have helped IQ a bit. I'm always forgetting something.
f/1.8 1/4000"
f/2.8 1/1600"
f/4 1/800"
f/5.6 1/400"
f/8 1/200"
f/11 1/100"
 Post subject: Re: comparison
PostPosted: Fri Jul 04, 2008 7:45 pm
I don't have the 18-55 kit lens, I bought my XT body only and got the 18-55IS but here is a lens comparison between the 50/1.8 and the 18-55 IS
Shot settings pretty much the same : ISO 100, WB - shade. I turned IS off since it was on a tripod and left mirror lock up off since I didn't use it with the 50/1.8
18-55IS @ f5.6
50/1.8 @ f5.6
18-55IS @ f8
50/1.8 @ f8
18-55IS @ f11
50/1.8 @ f11
PostPosted: Fri Jul 04, 2008 7:47 pm
Looks like the 18-55IS was set to 48mm. I eyeballed it so its not exactly 50mm
PostPosted: Sun Aug 17, 2008 10:59 pm
Not a bad lens, no 'real' focusing ring, you'll need to upgrade to the f/1.4 for a proper focusing ring.
A bit plasticky.
Some great results though:
More @ http://www.flickr.com/alexander_ward
PostPosted: Thu Sep 17, 2009 1:54 am
Personally for the cost I love this lens. It feels like a toy, honestly, and at f/1.8 it's quite soft (stop it up to f/2.0+ and its sharpness greatly increases, as seen in the example photos) in comparison to its potential sharpness. Because it's such cheap construction I feel a lot more secure about it on my body in case it gets bumped around it's easily replaced. $80 dollars is petty cash compared to the other 50s.
I haven't tried the f/1.4 or the f/1.2. From what I've heard they're spectacular. But from what I've seen from this lens, besides the bokeh not being completely circular (because of the lower number of aperture blades), I have very few complains. The focusing system is loud and sometimes inaccurate, but because it's a prime it's relatively easy just to switch it to manual and focus.
PostPosted: Mon Sep 21, 2009 6:20 pm
Thanks for review. I'm about to pick up this lens with D300.
