It is currently Mon Jan 23, 2017 11:14 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Feb 10, 2013 10:10 pm
Great angle AlainL - and welcome on-board!
PostPosted: Thu Feb 28, 2013 7:58 pm
Here is the strap on my camera.
image by Cujo1976, on Flickr
Camera: Nikon D60
Flash: Nikon SB-910
PostPosted: Fri Mar 15, 2013 11:23 pm
I already got the strap in january but somehow I missed taking a picture of my camera and the strap - but now here's it:
PostPosted: Sat Mar 16, 2013 1:08 am
The 5D3 is a beauty innit? :D
Some flappy mirrors and lots of glass
PostPosted: Sat Mar 16, 2013 8:57 am
Oh it is! (By the way: Our equipment looks pretty similar - 5D3, 580EX II, 24-105, 100mm 2.8L Macro, 100-400mm, Velbon Sherpa 600R - I just have the Sigma 12-24mm instead of the Canon 17-40mm and only a 500D instead of a 7D. Finally I'm missing some prime lenses.)
PostPosted: Sat Mar 16, 2013 5:01 pm
Yeah, indeed we do have pretty similar equipment, apart from some primes
How do you like the grip for the 5D3? Is it original or third party?
PostPosted: Wed Mar 27, 2013 1:47 pm
That's the original grip. For cheaper bodies I'd buy a third party one but on a 5D3 I wanted the original grip.
By the way: You can take off the shoulder pad of that strap and then (depending on how thin you are) the camera can be carried like a belt. Once I removed the grip, used my small 28-105mm lens instead of the 24-105mm and then I had a quite small set. I really like that strap!
PostPosted: Sat Apr 27, 2013 11:46 pm
There are two connectors on the strap so I can hook them up with two bodies...the D3100 does not look so compact with the lense and flash mounted...
PostPosted: Tue Jun 11, 2013 6:14 pm
So, as promised, here's a picture of my Camera Labs strap installed on a Sony Alpha A580 with Sony VG-B-50AM vertical grip using both connectors.
Sony von OliverSch auf Flickr
PS: How do I add an attachment? I think I haven't been cleared for that. :(
Edit: Thanks, Cujo, that's my first time on Flickr... :oops:
Show me a completely smooth operation and I'll show you someone who's covering mistakes.
PostPosted: Tue Jun 11, 2013 10:14 pm
Hi Oliver,
To share photos you click on this button in Flickr
sharing by Cujo1976, on Flickr
Then select the third option for the HTML/BBCode. At the bottom select the size you want to share and select BBCode. Copy the text in the box above and paste it in your post.
Kind regards,
Cujo
Camera: Nikon D60
Flash: Nikon SB-910
PostPosted: Wed Jun 12, 2013 12:57 pm
Thanks, Cujo, now it works. :)
