It is currently Wed Jan 18, 2017 6:57 pm
 Post subject: Canon 10-22 flare
PostPosted: Thu May 30, 2013 9:05 pm
Hi. New lens and had some photos I'm really happy with. However on quite a few I have had some degree of flare taking the form of an orange circle (see below) - first picture only one I've had where quite that strong! Camera shop reckon lens is fine, flare to be expected on occasion and I need a hood. I keep reading comments that the lens is really flare resistant and therefore wonder if the issues I have are unusual. If this is normal I can certainly live with it but would really welcome advice on whether it is and other users' experiences.
Thanks.
 Post subject: Re: Canon 10-22 flare
PostPosted: Thu May 30, 2013 10:32 pm
Because the lens is so wide angle, a hood is of limited benefit.
As a further thought, do you use a protection or UV filter on the lens? If so, try removing it.
PostPosted: Fri May 31, 2013 7:00 am
No filters used. Shop did suggest that might help but get feeling from posts on related subjects that cause as many problems as they solve. Thanks for replying.
PostPosted: Fri May 31, 2013 11:34 am
To clarify, I was saying if there was a filter, removing it might help. But if you're not using one, that's moot.
PostPosted: Fri May 31, 2013 4:07 pm
The key word there is resistant. This is not the same as flare-proof.
For comparison, here are some examples from a different lens that is known to flare.
Canon 5DIII, Rebel XTi/400D
Sigma 150mm F2.8 EX Macro
Canon 430EX II
PostPosted: Fri May 31, 2013 6:57 pm
Hi. Thanks! Think that sets my mind at once and for all that my lens is fine.
