It is currently Sat Jan 21, 2017 11:45 pm
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Where do you live?
USA 21%  21%  [ 9 ]
Canada 5%  5%  [ 2 ]
UK 37%  37%  [ 16 ]
European mainland 21%  21%  [ 9 ]
Australia 5%  5%  [ 2 ]
New Zealand 7%  7%  [ 3 ]
Asia and rest of world 5%  5%  [ 2 ]
Total votes : 43
PostPosted: Sat Jan 26, 2013 9:46 am
Hi Elduke, thanks for your order of two straps - they'll be great for the D7000!
PS - I actually emailed you to confirm whether it was indeed two that you wanted, so you may want to check your junk folder if it didn't come through. Since seeing your message here though I've posted two straps out to you using Airmail from the UK. Let me know when they arrive!
PostPosted: Fri Feb 22, 2013 8:38 am
Hello Gordon,
I have received both of my Camera Labs OpTech straps last week sorry for replying so late but I have been busy.
Nikon D7100
Nikkor 24-70mm/f2.8, Nikkor 35mm/f1.8, Nikkor 50mm/f1.8, Nikkor 70-200mm/f2.8 VR II, Sigma 8-16mm/f4.5-5.6, Tamron 80-210mm/f4.5-5.6, SB-900
On the list 14-24mm/f2.8, 24mm/f1.4, 28mm/f1.8, 85mm/f1.4, 105mm/f2.8, 400mm/f2.8, Nikon FX Camera Body
http://www.flickr.com/photos/dadude122
PostPosted: Thu Feb 28, 2013 6:25 pm
Sorry for the late reply here. My strap arrived without problems and I've been using it walking around with my D60 + 70-300mm lens on it for hours without any problems. Even if I add my SB-910 the weight is nicely distributed.
I do have both loops on the camera but when I'm going to take photos I take the left loop off for convenience. Once I finish taking the photos I'll snap the left strap back on for extra security.
Photo of the strap on the camera will follow. If there are still straps available I'll order my second strap in March.
Thank you very much for all the work you have put in this Gordon.
Camera: Nikon D60
Flash: Nikon SB-910
PostPosted: Thu Mar 07, 2013 8:09 pm
Thanks for the updates everyone!
cujo you can of course use the strap however you like, but it is designed to take the weight with just one connector.
PostPosted: Thu Mar 07, 2013 8:38 pm
Hi Gordon I realise that it's designed to take the weight with one connector. i clip in the second connector when I'm not taking a lot of photos for a bit of extra security. Once I am getting to the location where I want to take the photos the left connector is unclipped and there is no problem taking a photo. It's a very good strap.
Camera: Nikon D60
Flash: Nikon SB-910
PostPosted: Fri May 10, 2013 11:39 am
So, I got my OpTech strap after only a few days. Installation was rather easy although a bit fiddly, because the eyelet on the camera was on the slim side. For a right-handed person you must install the strap on the left side of the camera, otherwise it'll be in the way, i.e. in front of your face. :)
I'm using the strap with my Sony Alpha A580, I will get the original battery grip tomorrow, so I will fasten the second connector on that one.
Here's an image (taken with an Acer A700 tablet) of the installed strap:
http://sdrv.ms/16lO2Wk
Edit 11.05.2013: Got my battery grip today and installed the second connector to it. Works like a charm.
Show me a completely smooth operation and I'll show you someone who's covering mistakes.
PostPosted: Thu Aug 01, 2013 10:11 pm
I was given an optech utility sling strap as a present ( sorry not the cameralabs version) and having used it for a few days can really recommend it. It has the added virtue that you can attach alternatives - eg the hand strap - very easily. I was concerned about the security of those mini connectors / loops but so far they seem very solid and robust.
If Gordon does another run of these straps, dive in, you won't be disappointed IMO.
Nikon D600
Nikkor AF-S 18-35 f/3.5-4.5G, Nikkor AF-S 28-300 f/3.5-5.6G VR, Nikor AF-S 50 /1.8 G
