It is currently Thu Jan 19, 2017 7:30 pm
PostPosted: Sat Mar 02, 2013 12:22 pm
Trying to find a compact camera that has live output to a monitor/tv and record at the same time
without turning black, like my lumix. Working on a little project.
PostPosted: Thu Mar 07, 2013 7:57 pm
Most Panasonic cameras will output a live signal from their TV outputs if you first press and hold the trash button for a few seconds. BUT the output is normally in NTSC only, even if it's a PAL model, and you may also have some icons over the view.
PostPosted: Fri Mar 08, 2013 4:16 am
Thanks Gordon. Do you have any suggestions on what would be good?
Cause I know on some the live output goes blank when you start to record.
