It is currently Wed May 22, 2013 7:21 am
PostPosted: Mon Jan 28, 2013 8:52 am
M56 - the globular lost in the Milky Way background by cybermystic, on Flickr
Hyperstar III image - processing by Noel Carboni. The globular cluster M56 is almost lost in the Lyra Milky Way background.
Greg
PostPosted: Mon Jan 28, 2013 7:10 pm
Amazing work as usual Greg.
I don't get to see even a tiny proportion of the number of stars in that image when I look at the whole of the night sky from here (assuming it's not raining!).
Dent, Arthur Dent.
Pentax k-30 and k-x with DAL 18-55mm and DAL 55-300mm, Tamron 18-50mm and Camera Labs Straps.
PostPosted: Tue Jan 29, 2013 10:14 am
That's the difference between the Mk1 eyeball and the CCD :D I spent 2 years visually observing through the C11 before I put a CCD on. When I saw from the very first CCD image how many more stars you get in the field of view compared to what you see through the same optical setup - I never went back to an eyepiece. Not actually "looked" through any of my scopes since 2004 :(
Greg
