Bri wrote:
I do have CS5 but never considered it for audio. Can you head me in the right direction.
Just to be clear, I meant the full CS5 suite, not just Photoshop. Assuming you also have the full suite, or at least Premiere and/or Soundbooth and/or Audition, you can either:
Open the video file in Audition which will automatically separate the video from the audio. Just ignore the video, and do what you want with the audio.
Open the video file in Soundbooth, then "Save as..." an audio file. e.g. .wav, .mp3, etc.
Open the video file in Premiere, right-click the file and select "Edit in..." either Audition or Soundbooth, then proceed as above.
pierovera wrote:
Well I'm not sure if it would work, but with other file formats it has worked perfectly. Giving it a try wouldn't cost anything, would it?
Since Quicktime does
not support AVCHD, attempting to open an MTS file could corrupt the file. So while this may not cost anything monetarily, it could cost the "memory" of whatever was recorded in the file and/or the time it will take to recreate the footage.
