It is currently Wed Jun 19, 2013 10:31 am
 Post subject: Extracting sound track
PostPosted: Fri Nov 23, 2012 12:42 pm
I have a video recorded on a GH1. I would like to extract the orchestral sound track from the video without going through speakers and re recording. In other words doing it digitally. I have had a bit of a play around with no success. Has anyone any ideas I might try. Cheers in advance
PostPosted: Fri Nov 23, 2012 1:32 pm
First off I'm not a techie person, but can you just download it to your PC?
PostPosted: Fri Nov 23, 2012 8:56 pm
Yes I have downloaded the video file to the PC. I want to use the soundtrack from the video for another purpose so will need to create an audio file which is where my problem begins.
PostPosted: Fri Nov 23, 2012 10:11 pm
Hopefully someone here will be able to help you out. I wouldn't have thought it difficult to do, but presumably it'll be a case of converting something, then just `burning` it to a CD? but then again is the soundtrack actually recorded seperately from the movie? It may be part of the movie.
PostPosted: Sat Nov 24, 2012 12:30 am
Xilisoft AVCHD Converter
Or you can Google for "extract audio mts" along with your OS and desired audio format.
I use CS5 myself, but I'm assuming you don't want to spend that much - Mark
PostPosted: Sat Nov 24, 2012 2:49 am
Or maybe you can do what I do:
Open the movie in QuickTime Player and then go to File>Save As and in the file format select the format you prefer, but be sure that it says "Audio Only". Hope it helps :)
PostPosted: Sat Nov 24, 2012 5:48 am
You've done that successfully with a (Panasonic GH1) AVCHD/MTS file?
PostPosted: Sat Nov 24, 2012 11:43 am
Thanks Maertro. I do have CS5 but never considered it for audio. Can you head me in the right direction.
PostPosted: Sat Nov 24, 2012 12:34 pm
Well I'm not sure if it would work, but with other file formats it has worked perfectly. Giving it a try wouldn't cost anything, would it?
PostPosted: Sat Nov 24, 2012 1:44 pm
I'll give that a try Pierovera. Cheers
PostPosted: Sun Nov 25, 2012 3:41 am
Just to be clear, I meant the full CS5 suite, not just Photoshop. Assuming you also have the full suite, or at least Premiere and/or Soundbooth and/or Audition, you can either:
Open the video file in Audition which will automatically separate the video from the audio. Just ignore the video, and do what you want with the audio.
Open the video file in Soundbooth, then "Save as..." an audio file. e.g. .wav, .mp3, etc.
Open the video file in Premiere, right-click the file and select "Edit in..." either Audition or Soundbooth, then proceed as above.
Since Quicktime does not support AVCHD, attempting to open an MTS file could corrupt the file. So while this may not cost anything monetarily, it could cost the "memory" of whatever was recorded in the file and/or the time it will take to recreate the footage.
PostPosted: Sun Nov 25, 2012 3:46 am
Well that's good to know, but that's why you should never work with the original file, always work with a copy :)
PostPosted: Tue Dec 18, 2012 11:23 am
Managed to achieve what I wanted with "Avid Studio"
PostPosted: Tue Dec 18, 2012 9:57 pm
That's good, thanks for sharing your solution, I might find it useful some day :)
