It is currently Tue May 21, 2013 2:45 pm
PostPosted: Fri Oct 05, 2012 4:35 pm
I do have a Canon EOS Rebel, and I am considering to buy a better camera such as the 5D Mark II, but those are pricey specially bundled with the lenses and all paraphernalia; so I am thinking on buy the body to start, but I do not if I can use the three lenses that came with the Rebel. Are they interchangeable? Is the quality an issue here?
Thanks and regards, for your advice and support! NICOLAS
PostPosted: Fri Oct 05, 2012 4:40 pm
Lenses designated "EF-S" will not fit on 5D class bodies. EF lenses and 3rd party lenses are generally ok. This limitation was a design feature of the EF-S lenses, as they're allowed to get closer to the sensor on supported bodies. The bigger mirror on the 5D would run out of space if the lens could fit.
PostPosted: Fri Oct 05, 2012 5:03 pm
Thank you very much. Abusing of your patience, I do have a problem on my Rebel: from time to time I get a very thin, small "worm-like" line on my images, is it a cleaning or an electronic issue? I changed the lenses but the problem remains and is not all the time. Thanks.
PostPosted: Fri Oct 05, 2012 5:33 pm
Sounds like dust on the sensor. You can get a cheap blower to try and shift it.
PostPosted: Fri Oct 05, 2012 7:45 pm
Thank you, I will try that right away.
PostPosted: Sun Oct 07, 2012 12:10 am
Addition: Old FD lenses won't fit Canon EOS cameras as well.
