It is currently Thu Jun 20, 2013 5:32 am
 Post subject: D3100 Battery Question
PostPosted: Sun Sep 23, 2012 11:17 pm
Greetings from Istanbul, Turkey!
I am an absolute beginner, so please bear with me if you find my questions silly or irrelevant. I just got my first DSLR a few days ago (D3100). I am thinking of buying an extra battery and was wondering if my local camera salesman would know which battery it is if I asked for a spare D3100 or are the Nikon batteries mostly compatible? Secondly, when I carry a fully charged battery in my pack, will it run out after a while without me using it? I am thinking of going on a hike and won't be able to charge batteries and would like to know whether they remain fully charged when not used for a while. I am asking because the my fully charged battery of my laptop runs out if I don't use it for a month or something.
Thank you!
PostPosted: Sun Sep 23, 2012 11:49 pm
Hi there and welcome to the forums!
I think you can expect to ask for a D3100 battery at your local camerashop and you would get one, but in case they don't know which is the battery, ask for the Nikon EN-EL14 battery, this is the Nikon battery for the D3100.
By the way, not all Nikon batteries are compatible with all the Nikon DSLRs.
Also, a fully charged battery should not discharge while not in use, because it won't be a really long time, as long as it is not in the camera, you can expect it to be fully charged when it's ready to use.
I hope I helped :D
PostPosted: Mon Sep 24, 2012 1:03 pm
Thank you. It's good to hear the battery won't run out if not used for a long time.
Since I have the kit lens for the D3100, what is the best way to protect it? Should I put on the hood every time I'm done taking pictures or should I get a UV filter for protection?
PostPosted: Mon Sep 24, 2012 9:14 pm
Well personally I like to keep the hood on at all times (yes, my camera might be a superzoom but it has a hood nonetheless). Also, probably it's not the best idea to buy a UV filter since they tend to degrade image quality sometimes, but if you use your lens in non-optimal conditions, I think it would be best to buy a UV filter.
