It is currently Fri May 24, 2013 12:04 pm
PostPosted: Fri Sep 07, 2012 9:22 am
Hi All,
I buy Canon 1000D in May 2010 and in this week I found that battery LP-5E is not working :( .
Battery discharge very quickly withing 10-15 shouts, and when i put it for charging it get charges within 15 minutes.
Is my battery dead?
Thanks and Regards.
PostPosted: Fri Sep 07, 2012 10:07 am
It's possible that it's dead depending on how regularly you charged it, particularly if the battery's charge hadn't been depleted prior to charging.
Have you tried charging it for the normal recommended time despite the light saying it is charged already?
PostPosted: Fri Sep 07, 2012 10:52 am
Hi,
How regularly I have to charge battery?
Is there is any problem of deep discharge because not charged for long time?
Because I will get this problem even I buy new battery.
I had charge for more time even light indicator show battery charged, but charger light goes OFF :(
Please help me.
Thanks and Regards.
PostPosted: Fri Sep 07, 2012 7:54 pm
Maybe it's your battery charger. Have you tried to use another charger?
Also it's a good idea to leave the battery to charge for longer, as suggested by Rorschach
PostPosted: Mon Sep 10, 2012 5:44 am
Hi,
Thanks all for reply.
Charging battery longer time help me :D ,
now it is been more confusing whether my battery dead or charger?
I am not having spare battery or charger, is there any other way to check out whether my battery is dead or charger?
Tushar
PostPosted: Mon Sep 10, 2012 8:30 pm
You could borrow a battery charger from a friend that has a Canon DSLR and see if it works correctly.
Anyways, it's good to know that you've fixed the problem :)
PostPosted: Tue Sep 11, 2012 5:14 am
Hi,
Thanks for reply,
Please help me out, I am looking for solution which will fix problem.
If I have battery charger with my friend I check battery before posting problem on forum.
Thanks and Regards.
PostPosted: Tue Sep 11, 2012 6:55 am
We don't assume that you would or wouldn't have done that since you never stated whether someone you knew had a suitable charger.
We can't really offer a solution without knowing whether the battery, the charger or possibly both are the cause of the problem.
Is it not possible to buy an inexpensive battery as a control? I can't think of a more practical or low-cost way to work out the cause of the problem if you don't know someone who has a battery or charger you could use.
PostPosted: Fri Sep 14, 2012 11:00 am
Hi,
I buy new battery and tested the charger, both r working fine :D
Now how can i take care of my new battery?
Thanks.
PostPosted: Thu Sep 20, 2012 8:31 pm
Modern Canon batteries don't have any memory effect so it does not matter if you let the battery completely discharge or not, I usually charge mine when it gets down to '1 Bar' remaining on the battery level indicator. Then I leave it on for 2.5 hours regardless of the charging light is on or off. For my 7D Canon recommend a discharged battery to charge for 2.5 hours.
5DMKII, 7D, 50D, (EF17-40-L-USM) (EF24-105-f4L-IS-USM) ( EF100-f2.8L-IS-USM) ( SIGMA 15mm f/2.8 EX DG Diagonal Fisheye ) (SIGMA 50mm f/1.4 EX DG HSM)
Holiday Home Rentals
