It is currently Wed May 22, 2013 10:19 am
PostPosted: Tue Aug 21, 2012 9:32 pm
Hello All, I have just moved to Nikon recently and I just bought D3x and 3 SB-910, I am just wondering how to set those flashes wireless to the Camera( slave) without using pocketwisard?
Any advices will be greatly appreciated.
Woody
Camera: 5D Mark II and 7D
Lens : Canon EF 85mm f/1.8 USM, EF 24-70mm f/2.8L USM, EF 100mm f/2.8L IS USM Macro, Canon EF 70-200mm f/2.8L IS II USM, EF 24-105mm f/4L IS USM. Tokina 11-24mm, canon 55-250mm, 18-200mm and 18-135mm
Newb: Zoom Telephoto EF 100-400mm f/4.5-5.6L IS (Image Stabilizer) USM Autofocus Lens, 70-200 f/2.8L II.
Going to sell: All my Canon Gears very soon..
Recently moved to NIKON
Nikon D3X, Pocketwizards, 50mm 1.4G, 85mm 1.2, 24-70mm 2.8, 3 sb-910
PostPosted: Wed Aug 22, 2012 4:59 am
Well presumably you got a good deal on the D3X, and strive megapixels.
No pop up flash and therefore no on board flash to use as a commander. Therefore you'll need pocketwizards or the like...
Or the SU-800 Wireless Speedlight Commander
Or use one of your SB-910s as an on board commander
Or a D800 with built in flash to act as commander, plus even more megapixels :lol:
PostPosted: Wed Aug 22, 2012 5:32 pm
Thank you very much for your advises, I suppose to have one flash on camera as a commander, is there anyway to set other 2(flashes) working as the slave? I have been setting them as slave many time but those two didn't fire?
One again thanks
Woody
PostPosted: Thu Aug 23, 2012 6:13 pm
Mount one of your SB-910 on your D3X and turn the power dial to "Master." Set the other two to "Remote." Make sure IR Sensor by the battery door on your two remote SB-910 have clear line of sight to the camera. Also make sure the Master SB-910 is set to activate the proper channel that the remotes are set to, active channel should have "0.0 EV" or other exposure values, inactive channels will read "--". You should also set the Master to "--" exposure so it doesn't contribute to the main exposure since direct camera flash is undesirable in most situation.
Nikon D800
Nikon SB-700, Nikon SB-600
PostPosted: Thu Aug 23, 2012 7:11 pm
Thanks Elro for your clearly advises. I am going to try it tonight and will get back to you by tomorrow
Woody
PostPosted: Fri Aug 24, 2012 6:05 pm
Hello,
I did as you said here last night, but other two flashes were firing late. It's off about 2 second I think. so, How do you correct it?
thanks
PostPosted: Sat Aug 25, 2012 4:46 am
Oh Oh!
PostPosted: Sat Aug 25, 2012 7:33 am
Go into your menu, under category "e. bracketing/flash" look for "flash sync speed" and set it at "1/250". I believe "1/250" is the max sync speed for the D3X. Put your camera on Manual mode, 1/250 of a second and any aperture.
Only reason I can think of your slaves firing late if they are set to rear curtain sync and you are test firing it with slow shutter speeds. In rear curtain sync the flash will go off at the last moment possible during an exposure.
Nikon D800
Users browsing this forum: KA734 and 1 guest
