It is currently Fri May 24, 2013 4:53 pm
PostPosted: Fri Jul 06, 2012 4:18 am
I have canon 50D, EF 50mmf/1.8,17-85mm f/4-5.6 and i want to buy a macro lens for nature photography.
PostPosted: Fri Jul 06, 2012 7:10 am
have you looked at the canon 100 Macro 2.8 or the 100 Macro 2.8L.
PostPosted: Fri Jul 06, 2012 8:33 am
thanks maxjj..
what are you think for EF-S 60mm f/2.8 USM .
PostPosted: Fri Jul 06, 2012 10:24 am
its a fine lens, but focal length is a bit short for macro. You need to get too close to the subject, that maybe an issue with insects etc. If you look at your 50 1.8 and zoom right in close on something, your results would be somewhat similar.
Unless you try extension tubes and the 50 1.8, you may need a tripod and need to use manually focus. I have not done this myself.
check out this link http://photography-on-the.net/forum/sho ... p?t=806478
PostPosted: Sun Jul 08, 2012 2:55 pm
60mm is equivalent to 96mm on FF. If 100mmL has good focal length on a FF, then why do you say it is too short? It has 1:1. I think it will be a fine choice, imho.
Olympus OM-D E-M5, Panasonic GF-3, Canon SX40HS
Panasonic Pancake 14mm f2.5, Panasonic Leica 25mm f1.4, Olympus Zuiko 75mm f1.8
Panasonic 14-42mm
PostPosted: Sun Jul 08, 2012 7:20 pm
On a FF body I'd prefer a 180mm Macro lens :lol:
The 100mm 2.8 is a great lens and I'd prefer the focal length over 60mm. Insects usually don't like cameras getting too close. On a full frame camera (who knows when you might want one :D) you can still use it and it's a great portrait and still acceptable macro lens. The 60mm is not full frame compatible, still yes: it is a sharp lens and offers 1:1 macro. I'm happy I've bought the 100mm version and sometimes I wish I had its bigger brother (even on a crop frame camera!) but the 180mm 3.5 Macro is just too expensive for me at the moment.
PostPosted: Mon Jul 09, 2012 4:37 am
Another option is the 150mm Sigma Macro.
There are two version of this lens.
I have the older, non-OS (Sigmas version of IS) as it was less expensive.
Canon Rebel XTi, BG-E3 Grip
Sigma 150mm F2.8 EX Macro
Canon 430EX II
PostPosted: Wed Jul 11, 2012 2:03 pm
thanks friends, many photographers like canon 100mm F/2.8 so i'm also going with them.
PostPosted: Wed Jul 11, 2012 2:49 pm
Sunil, the 100mm 2.8 usm is the best choice for APS-C.
Above this focal range the focal plane will be extremely low <0.5mm
The 60mm will give you better focal plane but you will need to get in closer.
There are online programs that you can use for free and check how f/; mm, and focal distance effect the image.
PostPosted: Wed Jul 25, 2012 7:40 pm
Well, Canon EF 100mm f/2.8 USM Macro Lens is an excellent macro lens and may be Canon's most fun per dollar lens. This is the lens I most frequently recommend for someone starting out in macro photography. :)
Last edited by Bjorn van Sinttruije on Fri Feb 15, 2013 3:28 pm, edited 1 time in total.
Removed commercial link from signature.
PostPosted: Mon Sep 17, 2012 12:02 pm
I replaced the 180 f3.5 L with the 100 f2.8L. The 180 is a superb lens, though the 100 is easier to handle. The 180 is a very heavy lens, so pretty tough to use well. The 100 is far more versatile, mainly due to the size and weight. I sold the 180 after 6 months with the 100, when I was sure which one I preferred. Hands down for me, the 100 is more suitable, even though you have less reach.
http://www.parismetrotrash.com
