It is currently Thu May 23, 2013 10:13 am
PostPosted: Mon Jun 04, 2012 9:55 am
I was testing a 2x TC on the moon. I wasn't too impressed with the results, so I went back out with the 1.4x TC. I took 8-9 shoots with each, and selected the best. I was able to resolve as much detail using the 1.4x TC. (100% crops)
1/320 sec, 400mm, F8, ISO400 (2x)
IMG_3361 fixed by bkslopper, on Flickr
1/320 sec, 280mm, F5.6, ISO 200 (1.4x) I tried F8 and ISO 400 as well, but this was a bit better.)
IMG_3369 fixed by bkslopper, on Flickr
I processed both in DPP, turned off noise reduction, used monochrome, +4 contrast, +5 highlights, -5 shadows, 5 sharpness, and set the EV at -1.5 (2x) and -1.67 (1.4x) to match as close as possible. I'm guessing a 15Mp crop sensor plus a 2x TC is beyond what the lens can deliver. I manual focused with the live view zoomed in all the way.
PostPosted: Tue Jun 05, 2012 1:29 am
did you used tripod ? 2x on 70-200 mk2 shud work even though there is drop in the fstop...
Canon EOS 5D mk III|Canon EOS 7D | 70-200 F2.8 L IS II USM | 400 F5.6 L USM
PostPosted: Tue Jun 05, 2012 12:43 pm
No I didn't use a tripod. This is with tripod and ISO100. Focus might have been slightly off because I had slightly sharper shots @ ISO400.
IMG_3377 fixed by bkslopper, on Flickr
PostPosted: Tue Jun 05, 2012 1:10 pm
Be careful that you aren't subject limited. Or more precisely, the moving air between you and the moon being the limit.
PostPosted: Wed Jun 06, 2012 11:07 am
Just to check if I got it right: The higher the moon is in the sky the less "atmosphere" is between the moon and you so the image quality improves?
PostPosted: Wed Jun 06, 2012 11:35 am
While there is less air to go through overhead than low on the horizon, the problem is more if that air is moving or not.
PostPosted: Sat Jun 09, 2012 4:33 pm
I take it all back. With the right focus and conditions, the 2x convertor can still get decently sharp images. Also, Popo brings up a great point about the atmosphere. Sometimes when viewing the moon @ 400mm, it's like looking at a BBQ grill with the heat distortions. This is one of the best images with the 2x + 70-200mm combo I've gotten so far. I disabled noise reduction, boosted contrast to +4, and set Sharpness to 5 from a scale of 0-10. F8, ISO 100, with 1/80 shutter. 100% crop on a 15MP APS-C sensor. I don't know why I've been fixated on the moon lately. Oh, I know. It's bright, slow moving and full of detail. Easy mode.
IMG_3385 fixed by bkslopper, on Flickr
