It is currently Tue Jun 18, 2013 8:24 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu May 31, 2012 11:34 pm
Hi Thomas,
I think RAW comparisons have a place in reviews as well as the standard JPEG shots. Some of us will be content with out of the camera JPEGs while others shoot exclusively in RAW. But weren't those sharpening settings something you developed?
PostPosted: Fri Jun 01, 2012 2:45 pm
Bob Andersson wrote:
Gordon has done an interesting "Olympus E-M5 vs Panasonic GX1 / G3 noise (RAW)" comparison which you can read here.
The E-M5 wins and it seems quite clear that it doesn't use a version of the GX1 sensor.
A very interesting comparison thanks. I have found that with the M5 the noise at high ISOs using RAW is lower than my Olympus PM1 with the 12MP sensor. I'd say by at least 1EV.
Frank
PostPosted: Sat Jun 02, 2012 9:35 am
Since acquiring my E-M5 I've not been keeping up with the latest reviews (why would I? :lol: ) but I thought I'd share this one by Ming Thein since it sums up my own feelings about the camera pretty much exactly and has a great selection of much better photos than I could produce to go with it.
The only points I'd take issue with, and this is real nit-picking, is that we now know (thanks, Gordon) that the E-M5 sensor isn't the same as that in the GX1 and there is now a second weather resistant lens to take advantage of the E-M5's own weather resistance, namely the Lumix G X Vario 12-35mm/F2.8 ASPH.
Boy, but that looks pretty even if there is no point in leaving the Power OIS switch set to On with the OM-D E-M5 body. :P
PostPosted: Sat Jun 02, 2012 10:22 am
I haven't paid attention on one detail: does the body IS work during composition or only during exposure?
PostPosted: Sat Jun 02, 2012 10:54 am
There's an interesting interaction, at least on my LEICA D VARIO-ELMAR 14-150mm/ F3.5-5.6 ASPH./ MEGA O.I.S. (oh, how I miss Canon's simple but effective naming!!!). I haven't tested all the combinations but I normally have my E-M5 set up so that IBIS kicks in on a half press of the shutter button. In that mode if I set the lens IS to On the stabilisation kicks in full time until I half press the shutter button at which point stabilisation appears to turn off completely (body and lens) if the view through the viewfinder is any guide. Whether IBIS reasserts when the shutter button is fully pressed isn't something I've tested as it just doesn't make sense to try and operate the camera like this so far as I'm concerned.
If I turn of the body's IBIS and turn on the lens based IS then image stabilisation works full time. Not having access to a LUMIX G VARIO 100-300mm / F4.0-5.6 / MEGA O.I.S I've no way of knowing but it occurs to me that lens based IS might be more effective and/or sensor-friendly when zoomed in to 300mm (600mm FF equivalent FoV) as in body image stabilisation would have to move the sensor around pretty violently. But on the new Lumix G X Vario 12-35mm/F2.8 ASPH the five axis IBIS of the E-M5 is surely the way to go...
PostPosted: Sat Jun 02, 2012 11:19 am
So the body IS can work for composition then? Thinking back to the old days (like my E-P1) when they didn't do that, it only kicked in during exposure itself. That was a disadvantage of body IS vs lens at the time. I guess the body vs lens debate continues particularly with longer focal lengths, but you got the best of both worlds there!
Not that I have any intention of re-joining mirrorless in the short term, it still pays to keep up with developments.
PostPosted: Sat Jun 02, 2012 11:34 am
The HLD-6 grip (free promotional offer for those of us who bought early) arrived this morning. As I expected I'm unlikely to use the portrait section but with that removed the grip adds very little height to the camera and certainly makes the camera a lot more secure to hold when a heavy lens is attached. As on the camera body there's a command wheel surrounding the shutter button on the grip and the ergonomics work well for me.
Shown above fitted with my "super-zoom" 14-150mm four-thirds "Leica" the gap between the grip and the lens body is tight but it's still possible (just) to fit my fairly large fingers in there without the middle finger rubbing against the lens and the extra security is worth that needed extra little bit of care. That gap isn't an issue at all when I'm using my regular m4/3 lenses and even when the Lumix G X Vario PZ 14-42mm is fitted the lens still protrudes further forward than the grip when the camera is switched off. As a result I'm going to leave the grip, sans portrait attachment, permanently in place for now but if the minimal extra bulk becomes irksome then I'll reserve the grip for use with heavier glass.
PostPosted: Fri Jun 15, 2012 9:31 pm
I was recently trying the E-M5 with the two grip options and like Bob, i was quite fond of the halfway solution which increases the depth and height of the grip, while also centering the tripod thread underneath.
Ken and I have almost finished our full review of the E-M5! Watch this space!
PS - does anyone have any anecdotal evidence on the environmental sealing of the E-M5? Don't forget the weather-sealing thread in the off-topic section too!
PostPosted: Wed Jun 20, 2012 10:35 pm
The Olympus OM-D E-M5 review is now up. Hey, I even got to watch the master reviewer (Gordon) work his magic comparing my E-M5 and the GX1 noise levels (here). 8)
PostPosted: Thu Jun 21, 2012 5:16 pm
A pleasure working with you Bob!
PostPosted: Sat Jul 07, 2012 8:28 am
Gordon was right on the money when he discovered that the E-M5 sensor isn't made by Panasonic. It seems (source) that Sony makes it, 8)
PostPosted: Thu Jul 12, 2012 7:37 am
Two pieces of E-M5 news today:
  1. OM-D E-M5 Version 1.2 Firmware
    Improved sleep recovery operation.
    AF target is indicated when using C-AF+TR while shooting sequential images using Sequential L setting. - Added function to automatically move focus to the following zoom positions when underwater macro mode or underwater wide mode is selected. (Only when M. ZUIKO DIGITAL ED 12-50 mm F3.5-6.3 EZ is attached)
      Underwater wide mode: Wide setting
      Underwater macro mode: Telephoto setting
  2. DxO Optics Pro v7.5.2: support for the Olympus OM-D EM-5, and 300 new DxO Optics Modules
    DxO Optics Pro 7 now supports the latest high-end micro 4/3 camera from Olympus, the OM-D EM-5, along with the Panasonic Lumix DMC-FZ150 and the Panasonic Lumix DMC-GF5. More than 300 new camera/lens combinations have been added since the previous version.
The camera firmware update is available via Olympus Viewer 2 - great system if, unlike me, you regularly use that software.
PostPosted: Tue Oct 02, 2012 8:51 am
Olympus have now released OM-D E-M5 firmware 1.5.
I updated from v1.2 using Olympus Viewer 2 as usual and the first upgrade only got me as far as v1.4. A further pass through the upgrade process got me up to v1.5. As you can see from the list below (source) the upgrade is worthwhile.
    Ver.1.5 (Oct. 2, 2012)
  • Operating sounds in the photo ready mode were decreased.
  • Use of the Image stabilizer function by setting the Focal length of an OM lens attached with an adapter was enabled even in Movie mode.
  • All updates up to version 1.2 are included.
    Ver.1.4 (Oct. 2, 2012)
  • Update functions for firmware version 1.2 have been modified. Camera functions are the same as version 1.2. After updating to ver. 1.4, please update the camera to ver. 1.5.
    Ver.1.3 (Oct. 2, 2012)
  • Update functions for firmware prior to version 1.1 have been modified. Camera functions are the same as version 1.1. After updating to ver. 1.3, please update the camera to ver. 1.5.
    Ver.1.2 (Jul. 12, 2012)
  • Improved sleep recovery operation.
  • AF target is indicated when using C-AF+TR while shooting sequential images using Sequential L.
  • Added function to automatically move zoom to the following zoom positions when underwater macro mode or underwater wide mode is selected.
  • (Only when M. ZUIKO DIGITAL ED 12-50 mm F3.5-6.3 EZ is attached)
    - Underwater wide mode: Wide setting
    - Underwater macro mode: Telephoto setting
    Ver.1.1 (Apr. 18, 2012)
  • Issue of updates stopping while updating firmware has been resolved.
  • Image stabilizer function when using the following lenses has been modified.
    - ZUIKO DIGITAL ED 8mm F3.5 Fisheye
    - ZUIKO DIGITAL ED 18-180mm F3.5-6.3
    - LEICA D VARIO-ELMAR 14-150mm
PostPosted: Wed Oct 03, 2012 9:25 am
It has been a long time coming but DxO have finally released their E-M5 tests. You can read the review here and compare the E-M5 measurements with other cameras here (I chose the Canon 60D).
PostPosted: Thu Dec 06, 2012 8:18 am
I am wondering in the review in ISO noise compare with NEX-7 was it taken into account the difference between actual ISO and stated Olympus ISO? Or was it just typical compare of Olympus ISO3200 to Sony ISO6400? :) I had both cameras and Sony was actually little better for me in proper test (with identical shutter speed and aperture).
