It is currently Tue Jan 17, 2017 9:53 pm
PostPosted: Thu May 10, 2012 7:00 pm
I've been asked to photograph a friend's art exhibition next month and one shot I'd like to achieve is by using a slow shutter speed to blur people's movement within the space.
I presume I'll need to buy an ND filter for this as it's a daytime tungsten-lit indoor shot. I've never tried this before so would appreciate any advice on the best way to go about it. I'll be using my Canon 40D and yes I do have a tripod. Thanks. :)
PostPosted: Fri May 11, 2012 1:28 am
If you're shooting under tungsten lights indoors, simply shifting to a low ISO and stopping your lens down will achieve the same effect. Unless you're dealing with spotlights, indoor lighting can be easily turned into long-exposure compositions :) Of course, if you're looking for shallow depth of field with those long exposures, 3-stop or greater ND filters would definitely be recommended.
PostPosted: Sun May 13, 2012 1:30 am
I do long exposure indoor shots all the time without an ND filter. Indoors is really really dark when compared to outdoors, even if it "looks" the same. Your eye compensates. f/8 at ISO100 should give you the slight blur effect you're looking for. I look forward to seeing the result!
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon Series E 50mm f/1.8
Nikon AF-S 70-300mm f/4.5-5.6 VR
PostPosted: Mon May 14, 2012 10:26 am
Many thanks for your comments Plymer and Trevor.
Both replies have been really helpful in demystifying the the process for me. Hopefully I shall have some good results to show off in a few weeks time. I'll have a little practice in the meantime too to try to simulate the likely conditions.
Cheers guys really appreciate it :)
PostPosted: Mon May 14, 2012 11:31 am
G'luck!
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
