It is currently Sun May 19, 2013 5:58 am
PostPosted: Fri May 04, 2012 7:43 pm
Hi just buoght the
SIGMA DC Macro 17 - 70 mm F/2.8-4.5 second hand on my nikon d90 how do i get below f4
with the 70-210 i set ap at 22 and camera does the rest
thaks steve
PostPosted: Sat May 05, 2012 2:12 am
Hmmm - might need a little more info, but basically run the camera in aperture priority and you set any aperture you like.
Are you referring to an aperture ring on the 70-210? I'm not familiar with that lens, but there isn't one on the 17-70, is there?
Basically, you would run the aperture through the rear control wheel and all should be good.
HCC
PostPosted: Sat May 05, 2012 7:11 am
hi
yes it is a aperture ring on 70-200 have tried the 17-70 on a mode wont go below f4 in auto should it not pick the lenses lowest in low light
thanks for your reply
PostPosted: Sat May 05, 2012 9:38 am
Just turn the Mode dial to ''A'', and turn the front wheel to adjust the aperture. That should work.
PostPosted: Sat May 05, 2012 10:15 am
Thanks rubin
tried this goes from f4 to f32 ? lens or camera faulty
PostPosted: Sat May 05, 2012 1:49 pm
You need to do two things to get below f4.5:
1. zoom out to 17mm
2. set focus to infinity
Now use the aperture ring again.
PostPosted: Sat May 05, 2012 2:01 pm
just tried this lens on a d300 and would not go below f4 obviously something wrong with lens
thanks everyone
