Quote:
Does anyone do a cheap and small high resolution (4MP+) mono?
Short answer - possibly not.
Looking through OPT's listings in price order I think the closest might be the 2MP
ATIK 320E which they sell for $1,105 (
here). By the time you've added shipping and import duty/VAT it's hardly cheap, except by astro-CCD standards, and you've still got to fettle your lens(es) onto it and mount the assembly on your astro-trac.
On the other hand, and you know I can be a bit naughty when it's other folks cash
, for not much more money than that ATIK you can buy a 6" Meade telescope on a computerised (equatorial) mount. Check out the
6" SC with LX80 Multi-Mount , the
8" SC or the
Series 6000 80mm apochromatic refractor, also on the OPT site. The 80mm refractor is probably the best for astrophotography simply because it's an f/6 as opposed to f/10.
On your wider point, I could never consider not having a GoTo mount now, especially if one can set it up in a semi-permanent way. You've seen my own pier solution which allows me to set up in the evening without having to polar align. But, for me, the key is the GoTo bit as it saves fiddling about trying to find targets. I can slew to a bright (enough) star to nail the focus and then command a slew to the area of interest quickly and repeatably. That means subs are pretty well registered even when taken days or weeks apart. Sell the astro-trac!
OK, I'll stop being naughty now. Like you I'd want to get the best out of my current investment but it can be fun window shopping and considering alternative solutions as well.
P.S. Bad luck about the car.
