It is currently Tue May 21, 2013 4:03 am
 Post subject: Lens for nex7
PostPosted: Sat Feb 11, 2012 3:31 pm
hello there folks,
This march i will buy the new sony nex7 body only.
What kind of leans should i buy?
18-55
50 - f1.8
55-210 ?
idk about lens, google and youtube told me that 50mm its a must buy, hehe.
i whant it for street photos, low light and some soft bokeh effect.
i don't have money for 3 lens, u_u, but a zoom lens will come in the near future, witch one its the best first lens ?
thanks!
 Post subject: Re: Lens for nex7
PostPosted: Tue Apr 10, 2012 7:02 am
18-55
50 - f1.8
55-210 ?
Forget about 55-210, definitely not on NEX-7. Get the SEL-18200 lens. A bit heavy, but pretty good all round.
I got my Sony NEX-7 (with 18-55) Kit, the 18-55 is all right, but you shouldn't have unreasonable expectation of it.
Tried SEL-50F1.8, good result, but not my style personally.
AntBlog701 | SillyDog701
Apple: MacBook Air (11-in, 1.8GHz i7), Mac Pro (12-core 2.66GHz), MacBook Pro (15-in), iMac (21.5-in, Core i5), Mac mini Server (2.66GHz), iMac (24-in, C2D), PowerBook G4 (12-in, 1.33GHz), iMac G4 (1.25GHz)x2, PowerMac G4 (dual 1.44GHz), iPhone 5, iPhone 4S, 4, 3G, iPad 4, iPad 3, iPad 2, iPad, iPad mini (all 64GB, LTE/3G), iPod touch (4th gen & 1st gen), 3 x AirPort Extreme, Time Capsule...
PostPosted: Tue Apr 10, 2012 2:40 pm
If you can afford the Zeiss, you will have the best package.
“I have held the new Sony Zeiss e Mount 24mm to a very high standard. The 24mm f/1.4 Summilux is a world-class benchmark lens, one of the finest fast wide angle lenses made. It is of course a full frame lens, while the E mount Zeiss covers APS-C. Also, the Zeiss is an autofocus lens, so in some ways we're comparing peaches and apricots. Also, there is more than a $5,000 price difference between the lenses.
Given all of the above, the 24mm Zeiss stands up to the Leica Summilux very well indeed. It bests it in some areas, holds its own in some, and falls slightly behind elsewhere. Overall this is a stunning performance. There is little vignetting, even wide open, and corners have very good resolution for a lens of this focal length and format. CA and flare is more of an issue with the Zeiss though.
Those photographers who have been clamouring for fast primes for the NEX mount are starting to have their requests met. With the 24mm f/1.8 Zeiss Sonnar Sony has produced a lens which photographers will find more than exceeds expectations. At $1,000 it isn't inexpensive, but then considering how well it holds up to the industry's benchmark, costing almost 6X the price, it actually is a relative bargain”.
http://www.luminous-landscape.com/revie ... w.shtml#24
PostPosted: Wed Apr 11, 2012 4:51 am
Thank you for the link.
Speaking about this 24mm Zeiss, I ordered it the day before my NEX-7 arrives, and still waiting...
PostPosted: Wed Apr 11, 2012 6:15 pm
Curious Antony why you would recommend against the 55-210mm on the NEX7? I don't have the NEx7 so it doesn't apply to me, but I do have the 55-210mm and use it very frequently on my NEX-5N - I'd consider it easily the best bang-for-the-buck lens made in eMount. The performance is very good, especially considering the price, the stabilization is excellent, and it has a very usable focal range for me - pairing it with the 18-55 for travel, or just sticking the 55-210mm on and going with it alone. I have 15+ lenses for my NEX line, but the 55-210 gets the most use. It often acts as a second body to my DSLR when I'm out birding with longer primes on the DSLR.
Justin Miller
Galleries:
PostPosted: Thu Apr 12, 2012 4:28 pm
I know that 55-210mm is cheaper than 18-200mm. 55-210 is not a bad lens, but the reasons I suggest 18-200 instead are:
For some reason, I feel that 55-210mm on NEX-7 just not sharp enough.
The original poster stated "street photos", and I assume longer zoom isn't that practical for street photography. I could be wrong on this.
18-200 covers better ranges, which means less need for changing lens.
55-210mm is a bit longer than 18-200. Perhaps due to the filter being smaller, it looks even longer than 18-200. On NEX-7, it feels like pointing out a bit too much.
Saying that, 55-210 is lighter to carry.
PostPosted: Thu Apr 12, 2012 10:47 pm
Thanks for the explanation on your rationale. Valid points to consider, and I definitely don't have the experience to know how it performs on the 7. Having all the info out there should help those looking at either lens decide which might be best for them and for the model of camera they're using!
Justin Miller
Galleries:
