It is currently Fri Jan 20, 2017 8:09 am
PostPosted: Sun Mar 25, 2012 5:31 pm
So, I had a big discussion with my sister about megapixels on a camera. She has a Canon IXUS 80 IS from like 2008, 8 MP and she wants a new camera because she says her cam doesn't make sharp pictures because of the 8 MP. She took a look on the internet and saw all them compact camera's with 16 and 14 MP and thingy's, and I told her the image quality doesn't lay on megapixels but she didn't believe me. She also doesn't know anything about her old Canon, her pictures where once very lowlight and blurry because she had chosen the worst settings te cam could have, saying it was *her cam's fold* that the pictures were bad. I showed her the difference between 16 MP and her 8 MP on a shot with exactly the same ISO, Apperture and shutter speed, and it turned out she thought I messed up my own settings -_-. I rely on the image uqality is about the size of the sensor but she didn't even know what a sensor was. MP was how good the picture was/ the higher the digital zoom the better etc. How can I prove her its not about the MP?
PostPosted: Sun Mar 25, 2012 5:44 pm
Hi Raven,
Find a stunning picture on Flickr which has about the same number of pixels as your computer monitor. Show it to your sister at 100% and after she's gone "Wow" explain to her how many megapixels it is! Probably about 2 unless you have a very swish monitor.
Unfortunately that won't work so well if she wants to print her photos and you'd also want to multiply that monitor megapixel count by about 4 to achieve good oversampling. All bets are off if she wants to crop digitally.
PostPosted: Sun Mar 25, 2012 5:53 pm
There's two things going on here. One is the eternal question of what is better at <i>a given technology level</i>, a lower or higher MP count. That's not so important here as the second fact. As a general trend, newer cameras have more MP. Everything gets improved over time, so in this sense, a new higher MP camera will tend to do much better than an old lower MP camera. This is not just sensor improvements, but also in processing and perhaps even lens design too. It all adds up.
At the end of the day, for this sort of application it doesn't matter if you have too many MP, as it is easy to resize down as needed afterwards.
PostPosted: Mon Mar 26, 2012 2:57 am
Explain to her that it's not the size but the girth that counts more.
I'd rather have a 12MP full frame sensor than a 12MP 'ickle' one in a P&S
PostPosted: Mon Mar 26, 2012 9:51 am
There are many ways to look at the pixel density discussion but if you do a quick internet search on "pixel density vs sensor size" you should find a few discussions on some areas of the topic.
Speedlight SB-700
http://keystrokesukimages.com
PostPosted: Mon Mar 26, 2012 1:44 pm
Makes me thinking about the Canon G5 review I read yesterday. People were all angry because of the 5MP sensor instead of the 4 on the G3. Who needs 5MP? On such a tiny sensor? (1/1,8'', even bigger than most of the compact camera sensors)
You really need a perfect lens to exploit those 5 MP... And what about the increase of noise and the decrease of DR?
Compare the G5's lens to the standard P&S lenses, and the size of the sensor (1/2,5'' vs 1/1,8'') and the increase of the MP count from 5 to 15. Okay, it's a bit offtopic, but the G5 cantake excelent photos. If you know how to use it. Let her see some photos taken by the G3 (4MP) and dont tell her how many pixels the picture has. After that... You get the point.
I know how youre feeling. I often have discussions with everybody. ''Ive got an iPhone, why should I ever buy a DSLR? My iPhone even has more MPs than your DSLR. So it's better. Before I forget to say: It has five lenses in it, you only have one.''
Lovely.
PostPosted: Mon Mar 26, 2012 2:42 pm
what you CAN do is take her camera out, take some amazing pictures and say, hmmm, nothing seems to be wrong with this camera, I take excellent pictures with this. I just have to adjust the settings, which YOU dont do...
Or, buy her a new samsung 16MP camera and let her take horrible photos with it and say, "so when will you start listening to someone who knows how to take photos?"
3) Canon 7D [EF-S 15-85 & 70-200mm f/4 IS & 50mm f1.4]
4) Leica M [50mm Summicron Pre-aspherical - Silver]
http://www.poetproductions.net
PostPosted: Mon Mar 26, 2012 4:10 pm
Well - this shot was taken with an Olympus E100RS with 1.3MP (on a 1/2" chip) that was released in 2000:
http://simon.deobald.org/bilder/p5063220.jpg (Original shot, no PP)
Well - the picture is small but the quality isn't bad.
I can't say anything against a new camera but it's definitely not about the MP. Why the would someone buy the Canon EOS 1DX for 6000+$ if the image quality of a 150$ compact camera with 16MP should be close to that? Show her that forum and our answers :lol:
It's about the sensor (size) and the quality of the glass in front of it. The MP are only a way to count the pixels (=size of the images).
PostPosted: Wed Mar 28, 2012 10:38 am
It's not a bad picture considering it's age and for example it took phones 6 years to yield similar results at a higher resolution. And then with varying results on focus and exposure.
PostPosted: Wed Mar 28, 2012 11:54 pm
Easy solution. Take her camera out and take some great photos in daylight and then under low light and show how the same camera can capture really fine photos at low ISO, and then rather unspectacular ones at high ISO when there's not enough light. You could do a side by side test with two cameras to prove that both cameras suffer the same at low light.
D: iPhone 4S, Canon 5DmII, Panasonic DMC-LX3, Fujifilm F30, Canon 30D, Nikon CoolPix 8700 | A: Leica M3, Holga 120N, Contax Tvs, Polaroid Spectra, Canon 50E, Rolleicord, Canon AE-1P
Canon lenses: 16-35L II, 24-70L, 50 1.4, 70-200 2.8L IS, 10-22
PostPosted: Thu Mar 29, 2012 2:18 am
That sounds like a good solution :)
PostPosted: Thu Mar 29, 2012 5:24 am
Your sister is female, don't you know you can never win. :roll:
PostPosted: Fri Mar 30, 2012 12:10 am
If you don't mind the shameless self-promotion, I took all these concert pics with my 4-megapixel Nikon D2H, except for the last one: http://www.flickr.com/photos/peppel/set ... 476886977/
