It is currently Sat Jan 21, 2017 8:44 am
 Post subject: AF-Assist question
PostPosted: Wed Feb 29, 2012 6:41 pm
Hello to everyone in this friendly forum,
I have just upgraded from my trusty D80 to a D300.And i have an issue that i can't figure out atm.
When i attach my sb-600 to the camera and i was used to use the af-assist from the flash when taking pictures in clubs , cuz that is what i mostly do now.But it doesn't seem to light , even if i turn on or off the af-assist from the camera.The af assist from the camera lights up no problem but i can't get the one from the flash to light.I tried in M,A,S,P mode with the af- on single servo focus,auto focus area mode.
It maybe a simple solution and a rather stupid question but i thought i would ask knowing that there are a few D300 owners around :).
Ty in regards.
PostPosted: Wed Feb 29, 2012 8:18 pm
Try spot or centre weighted metering- I think that may do it
PostPosted: Wed Feb 29, 2012 9:56 pm
Tried that.Still nothing.It can't be the flash cuz it worked on the d80 just fine.
Can it be the lens ?
PostPosted: Wed Feb 29, 2012 11:07 pm
Set your autofocus to AF-S, not AF-auto or AF-C
EDIT: ah, you already tried
PostPosted: Fri Mar 02, 2012 2:30 am
well strange thing.The af-assist problem seems to have come from the lens.I was using a Tokina 11-16mm 2.8 ... tried another lens and it worked ... don't understand why !?
PostPosted: Fri Mar 02, 2012 9:55 am
put the focus point in the center.
there's not too many points where this will work. but it should definitely work in the center.
