It is currently Sat May 25, 2013 10:59 am
PostPosted: Mon Dec 05, 2011 12:42 pm
hey guys. i am planning on buying this motherboard FOXCONN INFERNO KATANA and i all ready have the ATI 3870 512mb GDDR4 graphics card. If i install my graphics card on the new motherboard will it work? Thanks in advance.
antivirus coupon
PostPosted: Mon Dec 05, 2011 1:18 pm
It will work, but this isn't a problem with any motherboard with PCIe 16x support.
Any reasons to why you are buying a motherboard with 1156 instead of 1155? 1155 is a tiny bit cheaper per Mhz*
Also, this motherboard supports crossfire and 3-fire. But the two red PCIe slots are too close to allow graphic cards with dual slot cooling.
PostPosted: Wed Dec 07, 2011 3:21 am
**** Update ****
The Core i5 6xx processors (dual-core) really weren't that great, even 3 years ago. Better than a Core 2 Duo, sure- but overpriced. The Core i5 7xx processors (which were true quads) only cost about $10-$15 more.
But nowadays forget LGA 1156 and go LGA 1155. Even the Core i3 2100 outperforms the original Core i5's.
Yes, that motherboard has a PCI-E x16 slot (three of them, actually) so it's fine. However, your power supply must be strong enough to support the Radeon HD 3870- which is a different issue from the motherboard.
Do you already have a first-generation LGA 1156 Core i3/i5/i7 CPU? If not, there's reason to buy a socket LGA 1156 motherboard, because the 2nd gen Sandy Bridge processors (socket LGA 1155) are much better performers for the money.
coupon dell inspiron
PostPosted: Fri Dec 16, 2011 3:54 pm
Any mother board can support the graphics card. If you have to install graphics card then there is always open slot available to plug a graphics card in it. Graphics card can extends your monitor's video quality.
