It is currently Sat Jan 21, 2017 9:54 pm
 Post subject: Hard to move filters?
PostPosted: Sun Nov 20, 2011 11:11 pm
It is frustrating when you want to remove or replace a filter, and it decides to stay put. No matter how you try, you can't grip it firmly enough to get the thread moving. My first thoughts were of cold chisels and hammers (!) but my eventual solution is to use a nylon cable tie long enough to go close around the circumference of the filter. If you put it on the right way the harder you pull on the tail, the firmer it grips, and it soon starts the rotation. They cost a few cents each and I now have a small bunch of them in my bag.
Brian,
Canon 5DII, 7D, EF-S 10-22, EF 50 USM 1.4, EF-S 60 macro EF 16-35 L USM, EF 24 -15L IS USM, EF EF 100-400L, Canon SX130
PostPosted: Sun Nov 20, 2011 11:31 pm
I have a jar opener that works on the same principle. One of the secrets is to keep an even pressure around the filter ring. If you concentrate it anywhere, it just grips harder.
PostPosted: Mon Nov 21, 2011 1:25 am
Once my 18-55mm IS lens + UV filter fell down - everything still worked but the filter didn't want to move a bit. Well - I can't really remember how I removed it but as far as I know I used a pair of pliers. Luckily that was the only time I had that problem.
PostPosted: Mon Nov 21, 2011 8:18 am
Well, this thread came in handy!
I have a polarizer filter that got stuck. Problem is the front part keeps rotating - as it should - and the back part is too narrow to get any significant grip. Any tips?
Canon 500D and 10D with grip; 580 ExII; 1D mark III
Canon EF 28-105 f/3.5-4.5 USM; Tamron 18-200mm f/3.5-6.3; Canon EF-S 18-55 IS (broken); Canon EF 50 f/1.8 II; Canon EF 100-400mm f/4.5-5.6 USM L IS; Canon EF 16-35mm f/4.0 USM L IS
PostPosted: Mon Nov 21, 2011 10:19 am
Too narrow even for the cable tie solution?
Brian,
PostPosted: Mon Nov 21, 2011 10:33 am
[smacks himself in the head]
Let me just run downstairs at our warehouse... :mrgreen:
PostPosted: Mon Nov 21, 2011 11:38 am
My friends, I have found a solution. Use a shoe! Really, it works so well. Preferably a flat one. Place it on the lens as if it were a lens cap, and rotate while applying mild pressure. Works like a charm :-).
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon Series E 50mm f/1.8
Nikon AF-S 70-300mm f/4.5-5.6 VR
PostPosted: Tue Nov 22, 2011 3:53 am
For me, I use a rubber band. It grips onto the filter better than my hand alone. There has been a time though that I had to bring it into the shop to get my polarizer filter off with a filter remover contraption they had there.
No charge but I tipped the guy a few bucks because he was really nice about it.
Nikon D40
18-55mm kit lens
55-200mm VR
50mm f1.8
quatary mono/tripod
Google+
Facebook
PostPosted: Tue Nov 22, 2011 1:08 pm
an easy way would be to use a hammer but that might just damage the whole thing xD
but perhaps one of those http://knol.google.com/k/-/-/3se06belyo ... opener.jpg
a flat rubberized jar opener.. it opens anything that gets stuck
http://www.AnderssonPhoto.com
Equipment: A blend of Canon, Nikon, Yashica, Leica, Voigtlander, Samyang and Sigma. All of which you can see on my website!
Wishlist: Leica M 240, Summilux 50 ASPH, Summilux 24 ASPH
PostPosted: Wed Dec 14, 2011 6:25 pm
Thanks to the unknown admins who responded so quickly to the spammer!
Brian,
PostPosted: Thu Dec 15, 2011 5:29 am
I used to just use the pal of my hand and press firmly over the whole of the front of the filter and turn.... albeit slowly
3) Canon 7D [EF-S 15-85 & 70-200mm f/4 IS & 50mm f1.4]
4) Leica M [50mm Summicron Pre-aspherical - Silver]
http://www.poetproductions.net
