It is currently Wed May 22, 2013 11:41 am
PostPosted: Mon Oct 03, 2011 12:49 pm
Probably going to buy a Sigma 30mm f1.4 lens in a bit. There are some reviews describing some focusing short. What's the best way to check the one I'm looking at doesn't?
Ian
PostPosted: Mon Oct 03, 2011 1:18 pm
My suggestion is: Put the camera down on some surface with a fixed distance to some object. Use manual focus in live view to get the center of the frame in perfect focus. Then exit live view and half-press the shutter to focus on the same spot with the traditional phase-change system. If the focusing distance window on the lens changes, the lens has front- or back focus
Canon DSLRs: 5D Mark III, 7D
My deviantART
PostPosted: Wed Oct 12, 2011 1:48 pm
don't just AF on the center,because the middle AF point is cross-type & that might influence the overall AF perfomance & precision of that lens. always try many focusing scenarios.
A Tamron 17-50mm that I tested failed completly (well it had serious front focusing issues),but only after I used all AF points,the middle AF point was much more accurate then the others. Focusing with the non-cross type points resulted in some looong hunting. (outdoors!)
Visit my work here
PostPosted: Wed Oct 12, 2011 4:30 pm
Try micro digital in Mall of the Emirates (first floor, above French Connection)
They sometimes have a selection of certain Sigma lenses so you may be able to try two copies. They'll give you a 10-15% off 'best price'
Normally the light isnt great in the store, but try close focussing on an angled advert/point of sale sign at a particular letter wide open or close to it.
PostPosted: Wed Oct 12, 2011 6:58 pm
Good point on the cross-type sensor, Razvan
My deviantART
