Simple question: Which area or areas in the image below look most like a deep red ruby colour to you?
I've added an indication of x and y coordinates so you can share your choice. Mine would be either
x=8 and y=3 or
x=3 and y=4. As you can see, I'm not going for great precision here but I might get an indication of how most monitors and the eyeballs viewing them are set up.
The question arose in my mind after having had a first look through my new narrowband Hα filter which just lets light through at a wavelength of around 656 nm. That is a very deep red and my Mark 1 eyeballs tell me that there isn't a computer monitor out there that any of us are likely to own that can actually reproduce that colour. The nearest colour that sprang to mind was "deep red ruby", hence the question.
As for the chart above, I produced it for future reference to help in picking colours for reproducing nebulosity from a range of narrowband data. It's not scientific in any shape or form having been produced by a bit of freehand gradient drawing but it does contain most of my intended future palette. Maybe I should have aimed for more yellow but yellow in large quantities isn't a colour I find particularly attractive in most astro-photographs. If yellow appears as a result of mixing an RGB palette then fine but I hope to avoid starting off with large gobs of it!
