It is currently Sun May 26, 2013 6:08 am
PostPosted: Mon Sep 19, 2011 12:06 am
Would I get the same results with a hdr image by taking a raw image and adjusting the exposure and saving it as a jpg. and doing this 2 or 3 times with different exposures then doing a photomerge?
Nikon D90 18-105, 35mm f1.8, Nikon 70-300mm
Nikon SB-600
Panasonic FZ28
Canon SD750
My Flickr http://www.flickr.com/photos/37592444@N03/
PostPosted: Mon Sep 19, 2011 12:21 am
You will get similar, but definitely not the same. The merged photo will be a lot nosier (grainy) this way. In addition to this, and perhaps more importantly, blown out parts will remain blown out and underexposed will remain underexposed.
Having said that, there is a niche for single photo HDR's. Photomatix has the option to load a single raw file and it does the adjusting exposures as you suggest internally. This is useful for subjects that are moving (animals, people, etc...)
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Tamron 17-50mm f/2.8
Nikon 50mm f/1.8
PostPosted: Mon Sep 19, 2011 1:12 am
I have done this with 2 different photos with descent results, what do you think? Here are before and after photos.
Nikon SB-600
Panasonic FZ28
Canon SD750
PostPosted: Mon Sep 19, 2011 1:55 am
You've definitely improved the photos for sure, so nice work on that. The only problem that I see is that the top of the first photo's sky seems to be blown out. As mentioned before, a bracket set would eliminate this.
Trevor Harris
Nikon D200
SB-600
YN-560 II
YN RF 603 x 4
Nikon 50mm f/1.8
