It is currently Thu Jan 19, 2017 6:31 am
 Post subject: Cwmcarn MTB
PostPosted: Sun Aug 28, 2011 6:03 pm
Some MTB shots from today, I tasked myself with going manual but battled with the sun and clouds all afternoon so not sure about them overall, there was another guy there using a flash but being an ex biker I'm not to fussed on a flash firing when I'm in mid flight but he said it was all about positioning and timing. I'd also have to brush up on my flash skills, I'm not to sure about shooting sport with a flash.
I'd love some C&C but appreciate they're a bit samey.
1
Cwmcarn by jkstacey, on Flickr
2
3
4
5
6
7
D7000 and too many lenses.
PostPosted: Sun Aug 28, 2011 6:31 pm
My C&C is from the view point of a crap photographer but an enthusiatic mountain biker :D
While they're not bad photos they're not great photos. Problem seems to me that the biker is not separated from the background, its actually quite hard to see them in most of the photos.
The view point you've got is great for catching the action but gives you a difficult back ground to shoot against. This is amplified by the dark clothes many of the subjects are wearing.
I guess a flash would help a lot by lighting the bikers so they pop and separate from the background in this location
Because of the clothing and bike in 7 the problem is dramatically reduced
PostPosted: Sun Aug 28, 2011 9:55 pm
From the point of view of a crap photographer and arthritic sloth, I pretty much agree with what @ianganderton said before - dark backrounds and dark tops.
I also agree with what you say about being reluctant to use flash and I don't think that the weather helped you too much either.
Dent, Arthur Dent.
Pentax k-30 and k-x with DAL 18-55mm and DAL 55-300mm, Tamron 18-50mm and Camera Labs Straps.....hang on, where's my towel?
PostPosted: Sun Aug 28, 2011 9:56 pm
Thanks Ian, That's pretty much what i was thinking and unfortunately most riders were in dark colours and Cwmcarn is a very green venue. If anybody can offer strobe advice in this situation that'd be great, I have an SB600.
PostPosted: Sun Aug 28, 2011 10:08 pm
And this guy was a dream to shoot, showbaoting with light clothing and a bright green bike.
Cwmcarn Panorama by jkstacey, on Flickr
PostPosted: Mon Aug 29, 2011 3:03 am
I saw this one on the "photo of the day" thread and its an excellent image, really like it.
PostPosted: Mon Aug 29, 2011 3:25 am
jkstacey - what camera are you using? Nikon CLS capable?
PostPosted: Mon Aug 29, 2011 7:12 am
Hi Phil I'm using a D7000 apart from the cls I also have a cheap radio flash sync.
PostPosted: Mon Aug 29, 2011 8:01 am
In bright light the CLS might not be effective unless you've got a master flash to aim at the IR on the SB-600 remotely.
In these overcast conditions the on board flash may trigger though - I'd suggest having a play.
Try youtube for balancing ambient and flash, outdoor stobe photography etc. You'll find a lot of anoraks taking photos of themselves on timer (!) but there'll be some useful advice in there.
http://strobist.blogspot.com/2006/03/lighting-101.html is another useful resource.
Once you've learnt and understood how to control the SB-600 remotely using the on board flash and menu, I'd pop outside in similar lighting conditions to practise with your gear on a stationary object at around the same distance you can get away with when photographing the cyclists. If you're SB-600 can produce enough power to illuminate the subject then you're good to go. Try using manual modes and TTL modes. The way the ambient light can be controlled can differ between manual and TTL - here's a good link:
http://neilvn.com/tangents/flash-photog ... e-shutter/
PostPosted: Mon Aug 29, 2011 8:04 am
So if CLS works in your outdoor scenario, you have two on board options for controlling your SB-600 - Full Manual or TTL
If the on board flash is overpowered by sunlight and doesn't trip the SB-600, the radio triggers will work in Full Manual mode only (unless you're got Pocket Wizard's new Flex system, which are pretty cool and expensive by the way!)
PostPosted: Mon Aug 29, 2011 8:19 am
Thanks i'm going to give it a go but perhaps when the riders are not so vulnerable to an off :lol: what about shutter speed? I was shooting at around 1/1000 sometimes more with a high ISO but the strobe will only allow 1/250
PostPosted: Mon Aug 29, 2011 8:53 am
Look at the D7000 manual - you'll be able to set up high speed synch to shoot up to 1/8000th.
If you're shooting in TTL with the flash controlled off camera by the on board flash, dialling in -1EV should reduce the ambient and flash exposure. Then dialling in +1 Flash EV on top will cancel out the Flash underexposure, giving a bit of separation between the subject and background.
This is where Nikon TTL differs from Canon TTL - in Canon I think changing the exposure comp. doesn't effect the flash, whereas in Nikon it does.
PostPosted: Mon Aug 29, 2011 10:03 am
this maybe a dumb question but I'll ask it anyway
Would shooting with a slower shutter speed, a flash and some panning movement not produce an effect where the background was blurred more and the subject frozen and so separating the subject from the background more.
Think about this subject has me looking back at these photos http://ianganderton.wordpress.com/2010/ ... hotoshoot/
These were taken by a magazine photographer and he used a remote flash held up high on a 'stick'. Definitely created some separation of the subject from the background
If I was biking and someone was taking photos with a flash I wouldnt be bothered as long as its not in my direct line of sight and blinding me. This is happening in daylight so its only adding a bit of light not providing ALL the light. The problems would occur in dark areas where a sudden flash would force your eyes to adjust and then not be able to see
PostPosted: Mon Aug 29, 2011 10:36 am
Yes - that's where rear curtain flash comes in.
Firing at the end of the actuation so the subject will be flashed at the end of the pan.
Or regular front curtain flash where the opposite occurs.
PostPosted: Mon Aug 29, 2011 10:49 am
But if you're shooting in Manual then the slower shutter will increase the ambient exposure and make the background lighter.
If you're in TTL mode the background will have the same exposure
