It is currently Wed May 22, 2013 8:54 am
 Post subject: OCZ Vertex 3 - BSODs
PostPosted: Sun Jun 19, 2011 7:09 pm
As some of you may have seen in another thread I recently built a new system. As part of that I went for the OCZ Vertex 3 SSD as main system drive. I had the odd crash or BSOD, and initially I put it down to mild overclocking or other tweaking, so I continually backed off, but still the crashes happen. The usual stability tests never showed up anything and it was quite puzzling me.
In a chance observation I saw a comment elsewhere the Vertex 3 and other OCZ SSDs were giving some users instability like I was seeing. I just read through this 18 page thread on their forums detailing observations on the erm... phenomenon if I can borrow the Canon wordage. A firmware update was released on Friday which I installed Saturday but a moment ago I had another crash. The frequency I'm getting is about one in several days on average with 24/7 running. Rather annoying. Previously they never reproduced it, but now they say they have, and a new firmware is in progress.
While of course it is annoying for the flaw causing crashing to be present in the first place, it is nice to know they are aware of it, have reproduced it and are in the process of finding a fix for it. It doesn't affect everyone, but it isn't no one either. So if you're thinking of getting a SSD, while the Vertex 3 is up there in the performance stakes, personally I'd be willing to trade that for stability. Maybe I should have gone Crucial m4 after all, but I'm not doing another reinstall at this stage!
PostPosted: Tue Jun 21, 2011 11:25 pm
The firmware update to version 2.09 is up. I had a BSOD earlier so that was a good time to power down and put the new firmware on, which I have done now. No crashes yet, but I'd want at least one week without incident before I consider it possibly resolved.
What is conspicuous by its absence is the lack of feedback from OCZ/sandforce about what it is they're fixing.
If I get another BSOD I think I'll be getting another SSD drive that doesn't use sandforce chipset. Again this reminds me why I said in the past I don't want to live on the cutting edge any more.
PostPosted: Wed Jun 22, 2011 12:09 am
It's probably just a coincidence but in the early days of SSDs I bought an OCZ one which kept corrupting Vista's files forcing me to reinstall the OS. After the third crash I sent it back for a full refund but I only got that after persuading OCZ to instruct my retailer that the device was faulty.
PostPosted: Thu Jun 23, 2011 12:47 am
Sorry to hear about that popo... My Vertex 2 recently passed 6 months of pretty constant usage with no problems...
PostPosted: Thu Jun 23, 2011 6:48 am
About 36 hours in and so far no further crashes.
For potentially affected models, I think it might only be the "3" series. At least that is where it is discussed in their forums. I haven't checked similarly for the older generations since I don't have them.
PostPosted: Thu Jun 23, 2011 6:26 pm
Still no BSODs :)
There's also a write up of the issue on anandtech here, as well as reviewing the even faster version OCZ recently bought out.
PostPosted: Sat Jul 30, 2011 4:14 pm
A minor update here. It's been about a month, and I've not had any of the BSOD issues I had before 2.09 firmware. Problem fixed! BUT - the fix was apparently to slow down various timings, which has resulted in a loss in performance. I can't quantify it exactly as I didn't do detailed before/after benchmarks, but it is a bit lower than other references on older firmwares.
I notice a few days ago they released 2.11 firmware.
Quote:
Issues resolved since version 2.09:
* Further improvements in drive recovery after unsafe power cycles
* Improved bad block managements increasing drive life
* Resolved a corner-case issue that’s related to drive not waking up properly from a low
power state
* Enhanced SATA PHY power management & timings for improvements with drive power
consumption and Intel chipset operational stability
All sounds good doesn't it? The staff on the forums are strongly recommending everyone go to 2.11, but what's holding me back is that there seems to be people who say they had problems return with 2.11 that were fixed in 2.09. It's not a flood, but it isn't none either.
I guess I'll play safe, it is ain't broke, don't fix it. 2.09 is working stably for me, and I'm not in the mood for another round of possible issues and fiddling around with another firmware update.
PostPosted: Sat Jul 30, 2011 5:07 pm
In case you haven't seen it bit-tech.net did some comparative tests of the OCZ Vertex 3 240GB (SandForce 2281 with firmware 2.02 and 2.09 as part of their Patriot Wildfire 120GB review.
PostPosted: Sat Jul 30, 2011 5:53 pm
Thanks Bob, haven't seen that before. Give or take some coarse rounding and averaging, let's say I'm losing potentially 10% of the drive performance from sticking with 2.09. Assuming 2.11 behaves like 2.02 that is. Maybe I'm getting old, but I'd take "works reliably" over "works fastest" these days...
