It is currently Thu Jun 20, 2013 10:45 am
PostPosted: Thu Jun 09, 2011 3:23 am
hi everyone
i just bought an umberlla and its so good
i used the continuous light and the result was great
but the problem is i dont know how to use the strobe light
everytime i take a picture its becomee so white
so can anybody help me plz
i hope everyone understand i am sorry i am not so good in english
PostPosted: Thu Jun 09, 2011 6:12 am
If you whole picture is coming out White it might be because your flash is set too bright. Can you upload an example so we can see?
PostPosted: Thu Jun 09, 2011 5:53 pm
yes the whole picture come so white
i dont know how to set the bright in my flash
could you help me plz?
PostPosted: Thu Jun 09, 2011 6:07 pm
What flash are you using a speedlite or strobe. I am guessing you are talking about strobe unless you have one of the new Canon 320ex flashes.
If you have a strobe you should be able to manually adjust the power. This will adjust the power of the flash aswell as the power of the continuous light aswell (that's what it does on mine and I think it is the same on most strobes. You could turn the continuous light on and adjust it to the power to what you want (this might be easier as you can actually see the difference with every bit you turn it up). Then turn on to the strobe and see if it has worked. You might have to fine tune it a bit but it should get you reasonably close.
PostPosted: Thu Jun 09, 2011 7:32 pm
yeah i am using strobe
but mine doesnt have a button to adjust the light
thank you jameswilby5 very much for your help
PostPosted: Thu Jun 09, 2011 7:44 pm
Close your aperture then.
And read more about flash :)
PostPosted: Thu Jun 09, 2011 8:42 pm
Yes I agree closing your aperture would definitely work. Or if you where going for a certain effect (LOTS OF BOKEH :D) you could always use a a quicker shutter speed. Although remember there is a minimum shutter speed that can be used with strobes they are usually in the region of 1/250th second.
PostPosted: Thu Jun 09, 2011 9:20 pm
i tried closing the aperture and it works fine
the picture were good
one more thing
:D
could you jameswilby5 tell me what strobe flash do you use ?
PostPosted: Thu Jun 09, 2011 10:54 pm
I use the interfit stellar x 300w. I bought it as part of the 2 head double soft box kit and am very impressed with it. I need to upgrade the tripods though as they aren't to sturdy.
PostPosted: Tue Jun 28, 2011 7:46 pm
Some flashguns do not have any controls on, just a power switch.
There are many out there.
Canon EOS 500D
