It is currently Tue May 21, 2013 9:54 am
PostPosted: Sun May 29, 2011 9:29 pm
First new toy is : Baader Herschel Wedge for White Light Solar viewing. It compatible with refractors only
The second toy is a Lunt 60mm H-alpha/B600/PT solar scope.
This is my setup : Image
I took this picture early this morning when I went out observing. now the cloud has set in. They will clear later tonight.
I will do some solar imaging later tonight and hopefully I can share with you guys. I can only use the Baader and my refractor with the DSLR until I get the new BF1200 2" diagonal from Lunt (They made an error on my original order). I will be using my DMK31 Monochrome CCD camera.
PostPosted: Sun May 29, 2011 9:39 pm
Looking forward to it! Good luck!
PS - I've edited your title so it's clearer what the thread is about.
PostPosted: Sun May 29, 2011 11:40 pm
Thx Gordon. While I was posting. The cloud's move away. I ran outside and capture for about 1 hour. I need to process my video in Registax now.
PostPosted: Mon May 30, 2011 12:33 am
First full disk. 3 video stick together
PostPosted: Mon May 30, 2011 1:02 am
Prominence
2nd prominence
Very active region (AR1226 i believe)
PostPosted: Mon May 30, 2011 2:15 am
In color
PostPosted: Mon May 30, 2011 6:26 am
Great! Very nice pictures to see!
PostPosted: Mon May 30, 2011 7:20 am
Very very cool! (or to be more accurate, very hot!)
PostPosted: Mon May 30, 2011 8:24 am
Very nice. That reminds me I keep forgetting to buy solar film to give this a try myself, as the more "affordable" solution.
PostPosted: Mon May 30, 2011 2:30 pm
You will see with a DSLR is even more difficult. the manufacture install IR/UV cut filter on your camera remove lots of details in the H-alpha spectrum.
PostPosted: Mon May 30, 2011 2:49 pm
What wavelength(s) were you imaging at? Even if the camera cuts out a lot of H-alpha, the sun would be pumping out a load too? Think the nominal loss is only 2 stops or so. Important for nebulae, but is it so important for the sun?
PostPosted: Mon May 30, 2011 3:02 pm
this picture were taken in the <0.7 Angstroms spectrum. The lower the angstrom the more surface details you will get. The sunspot should be easily visible. I think you can capture the umbra,penumbra. it's the prominence and surface details that is going to be hard.
This is a picture I took where I change the Angstroms value with the pressure tuner tilt on the solar scope. Its more like white light image of what you should expect from the Baader solar film
PostPosted: Mon May 30, 2011 4:24 pm
Ok, did a bit of a google around. I previously didn't think about it in too much detail, and though I'd just stick a filter on more for safety than anything else, and see what I get.
Given the repeated mentions of H-alpha, I have to assume that's where some interesting stuff is going on. Further to that, I take it the <0.7 angstroms reference isn't a wavelength (answering my earlier question on wavelength) but more a filter bandwidth as that's waaaaay outside of visible range.
I know it is going to be difficult regardless... even with all the brightness, given the sun is about the same apparent size as the moon.
PostPosted: Tue May 31, 2011 2:36 pm
Wikipedia :
H-alpha (Hα) is a specific red visible spectral line created by hydrogen with a wavelength of 656.28 nm, which occurs when a hydrogen electron falls from its third to second lowest energy level. It is difficult for humans to see H-alpha at night, but due to the abundance of hydrogen in space, H-alpha is often the brightest wavelength of visible light in stellar astronomy.
PostPosted: Sun Jun 05, 2011 12:11 am
Very nice results!
