It is currently Sat May 25, 2013 1:44 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Formatting Flash cards??
PostPosted: Wed May 04, 2011 5:24 pm
Hi all.
I've never formatted any of my memory cards before and now I'm wondering, should I? If I should when should I? And why should I? Sorry for all the questions :roll:
Im using flash cards on my Canon 50d
Thanks all
PostPosted: Wed May 04, 2011 5:31 pm
I think pretty much all camera manufacturers recommend that you format the card in camera before first use - check the manual. But it doesn't normally need to be done after that. I think that is to make sure nothing else did a funny format which might cause problems later.
The only other time I might format a card is if I have been copying lots of stuff on and off it. It would be a simple way to make sure nothing unwanted is left on it.
Do be aware it is a "quick" format that only erases the references to any files on there. It doesn't actually overwrite the actual data. It may be possible to undelete later and shouldn't be relied on to remove all traces of data.
PostPosted: Wed May 04, 2011 5:41 pm
Thanks for the speedy response and answering all my questions :D
PostPosted: Wed May 04, 2011 7:07 pm
There's just been a similar discussion originally in the Nikon section but now moved to this section. Probably best if I lock this thread and ask that discussion continues there to save repetition. Hope that's OK?
