It is currently Mon May 20, 2013 12:02 pm
 Post subject: Robber Fly portrait
PostPosted: Thu Mar 17, 2011 2:31 am
Robber Fly Portrait by Gustavo Mazzarollo, on Flickr
Blog
http://www.gmazza.com
PostPosted: Thu Mar 17, 2011 3:15 pm
That's awesome. :shock:
PostPosted: Thu Mar 17, 2011 4:22 pm
Virtually no depth of field - what f# was this taken at?
Greg
PostPosted: Fri Mar 18, 2011 2:58 am
This was shoot at f/5.6, but considering the extension of the lens the effective aperture is f/33.6
Blog
PostPosted: Fri Mar 18, 2011 8:52 am
Why do you have less than 5mm (?) depth of focus at f#33.6??
I would understand if this was f#5.6 but not f#33.6.
Can you explain (simply :)?
Greg
PostPosted: Fri Mar 18, 2011 9:51 am
from what i see it the closer you are the smaller depth of field is, and gmazza is know to get ultra close (i recon this fly was max 5 or 10 cm from the front element of the lens) and with extension at 5x you are working with 325 mm at super close distance witch gets you supper shallow..
correct me if i'm wrong..
btw gmazza another great shot..
add me up on:
flickr:
deviant art:
PostPosted: Fri Mar 18, 2011 1:04 pm
Having tried using the MP-E65 at 5x myself, I can definitely confirm the DoF is practically none unless you stop far too far into diffraction limiting. Then it only improves to "hardly anything". Certainly the DoF shrinks pretty fast at close focus/higher magnifications.
Oh, equation for effective aperture at higher magnification is along the line of
effective_aperture = set_aperture * (1+ magnification)
e.g. if you set f/16 nominal at 5x magnificaiton, the effective aperture is f/96. Unfortunately the effective aperture is what affects exposure and diffraction, so you get no light and soft image at that setting. Shooting wide open sharpens it a lot, but then you don't have DoF... gmazza does wonders in that respect finding the balance point. I haven't found it myself...
PostPosted: Fri Mar 18, 2011 1:17 pm
Ahh thank you for the explanation Popo :D I knew the MP-E65 lens was difficult to use, but didn't realise it was that picky. Very pleased I chose the 100mm Canon macro now.
So the only solution for a reasonable depth of focus with the MP-E65 lens would be something like the Helicon Remote software (tough to implement on a live subject)?
Greg
PostPosted: Fri Mar 18, 2011 5:37 pm
Unfortunately Helicon Remote wont work directly with the MP-E65 as it is manual "focus". Even if it could be, the focus is tied to the magnification and also changes the working distance, so things could go bad quickly. If you want to do a deep focus stack with it, then a motorised rail would help a lot. gmazza has used aperture bracketing before to work around that, one for the main detail and one to add relative DoF.
PostPosted: Fri Mar 18, 2011 8:15 pm
Helicon Remote is configured to run with a focus rail [StackShot macro rail].
Greg
PostPosted: Fri Mar 18, 2011 8:38 pm
Doh! I'm out of date on that one. I thought it only did focus control.
PostPosted: Sun Mar 20, 2011 3:09 am
Great shot Gmazza
Canon 400D. BG-E3. canon 18-55mm. canon 28-80mm. sigma 70-300mm APO macro.
PostPosted: Sun Mar 20, 2011 11:24 pm
Awesome pattern in the eyes!
PostPosted: Tue Mar 22, 2011 2:30 am
Thanks folks,
I have lost the track of topics, but popo is correct, as the lens extend, the aperture blades in this lens are positioned near the frontal element (the MP-E is a reversed lens from the start)so the "hole" the sensor "sees" is much smaller than the dialed aperture, f/16 @5x result in a effective aperture of f/96, as already said, well into diffraction territory.
Blog
