It is currently Sat May 25, 2013 11:29 am
PostPosted: Sun Jan 30, 2011 3:51 pm
44647_459041874972_37245004972_6293379_2219223_n by Chrispy61, on Flickr
Not sure if that link will work but thats what im looking to do.
Thanks
Nikon D90, MB-D80 Battery Grip
18-105mm f/3.5-5.6 VR Lens
Speedlight SB-600
Tamrac Expedition 5 Backpack
Sandisk Extreme 3 - 8gb
Vista Attaras Tripod
so far......
PostPosted: Sun Jan 30, 2011 4:35 pm
If you're asking how that's done, that's a flash technique with a slow shutter sync. Most cameras will have a slow sync option in their flash modes, and most external flashes are compatible with this as well. Most DSLRs will allow you to choose front or rear curtain flash, which determines when the flash will fire - at the beginning of the slow shutter or the end.
Essentially, the camera is metering and using a slower shutter speed as it would need to without a flash - in a dark environment, say a 1-second shutter, which would cause blur and light streaking with any movement. Sometime during that exposure, the flash is going to fire a normal flash (like 1/60 or 1/125) - either right at the beginning of the exposure, or right at the end of the exposure. The flash illumination will freeze any motion or action in the shot, but since the camera exposes for a longer period of time, any highlights or bright areas continue to pick up on the sensor, and will streak if you move. The photographer controls how much streaking, and the direction of the streak, by moving the camera in the desired direction and amount during the exposure.
Hope that helps.
Justin Miller
Galleries:
PostPosted: Sun Jan 30, 2011 4:45 pm
Makes sence, il have a go at that tonight.
Thanks for the help
Speedlight SB-600
so far......
