It is currently Tue May 21, 2013 11:28 pm
PostPosted: Thu Jan 20, 2011 5:31 pm
Greetings Pentax users.
I normally don't look at the Pentax section.
I'm a Canon user and don't have any plans to switch over.
However, my father-in-law has a Pentax camera and I was looking at it the other day.
One thing that seems really minor, but I liked a lot, was the hood. On his Pentax camera, the hood for his lens has a little section that pops out. I surmised that this allows for easy access to a polarizer filter and then explained it to my father-in-law. I thought it was a really nice feature to make using a hood easier.
I know this is a minor thing as most people don't think about their hoods, but there have been times where I've wished I had something like this on my gear.
Canon Rebel XTi, BG-E3 Grip
Sigma 150mm F2.8 EX Macro
Canon 430EX II
PostPosted: Sat Jan 22, 2011 5:45 pm
You mean those hoods of the Limiteds? :) They are nice! :)
| Pentax K5 | Pentax K10D | DA* 300 F4 | M 50mm F1.7 | Sigma AF 17-70mm F2.8-4.5 DC MACRO | AF 360 FGZ |
PostPosted: Fri Jan 28, 2011 8:30 pm
The kit lens has this feature on the hood :D
It is for the use of circular polarisers.
Perhaps you could 'convert' your Canon lens hoods - time to reach for the dremel :lol:
K10D + optimistic idiocy
My pic's - http://www.flickr.com/photos/10126769@N05/
PostPosted: Fri Jan 28, 2011 9:16 pm
Maybe somebody could put me right on this, if I'm in error.
Pentax DSLRs have an additional "Sv" - Sensitivity Priority" Mode on the dial. The ISO is user-set, and the camera then does the Aperture and Shutter. In "Program" Mode, it seems to do all 3, but WB can be set, rather than being camera-set, as in "Auto" Mode.
With my Fuji HS10, I rarely use Program Mode (apart from Slow Sync Flash, which doesn't work in other Modes) - but in Program you can select ISO as Auto within Ranges - 100-400, 100-800 - or tell it which ISO to use.
I've been assuming that DSLRs also have similar Program Mode settings - or, do they not? That is - if they do - why would Pentax have a Program Mode where ISO apparently isn't set - and Sensitivity Mode, where it is?
I don't yet have my K-5 to try this out - I'm going by the Manual - Page 95.
But, looking at other DSLRs, they seem not to have a "Sensitivity Mode" - so - as I'd been assuming - do they in Program Mode have Auto-ISO, Ranges for ISO, and User-Select 1 ISO....?
Dave.
