It is currently Sat May 18, 2013 7:16 pm
PostPosted: Wed Jan 26, 2011 3:35 am
Hi,
I want to buy a wide lens for my D7000. Any recommendations if to get the 10-24 DX or 12-24 DX?
Thanks!
PostPosted: Wed Jan 26, 2011 8:05 am
10-24, why? Same performance, more reach, cheaper
- Wout -
PostPosted: Wed Jan 26, 2011 9:17 am
Nikon wides are just not sharp enough...I would go with the Tokina 11-16mm F/2.8 or the Sigma 8-16mm. (also Nikon wides are pretty expensive)
Visit my work here
PostPosted: Wed Jan 26, 2011 9:19 am
I got the 10-24. Wider. I use it at 10-12mm 90% of the time probably.
PostPosted: Wed Jan 26, 2011 10:15 am
The reason you would buy a wide angle lens, is because you want to go wider than you already own, so why put yourself short and buy a lens that doesnt go as wide as possible? You should consider this when looking for wide angle lenses. The 8-16 is the widest you can go without going fisheye, you could consider that lens, but the 10-24 is a Nikkor and could give you more certain quality (Sigma is known for issues, but there are very good samples out there).
- Wout -
PostPosted: Wed Jan 26, 2011 10:30 am
The Sigma is much sharper than the Nikon...quality control is not a reason to dissconsider that amazing lens. Besides,one must test a lens or more before buying.
Visit my work here
PostPosted: Wed Jan 26, 2011 11:17 am
I am therefor careful with my wording, I said could give better quality, and not will :lol: everybody has their own preferences
- Wout -
PostPosted: Wed Jan 26, 2011 7:06 pm
10-24mm is a very exciting and practical range on a DX body.
I'd go for that.
PostPosted: Thu Jan 27, 2011 12:04 am
I agree with Razvan, the Tokina 11-16 f2.8 is a very good wide lens, its one of the cheapest and has constant 2.8 aperture.
I have the 11-16 myself and it is really good quality, both optically and build quality.
The only downside is the limited range.
Nikon D300s / 50mm f1.8D / 18-200mm VR / 70-300mm VR / micro Nikkor 60mm 2.8 / Tokina 11-16mm f2.8 / sb25 / Phottix cleon II
PostPosted: Thu Jan 27, 2011 7:58 am
I want to argue the wide aperture comment here, as the 10-24 starts at f/3.5 it is less than 1 stop difference and has a wider angle and bigger range. It also depends greatly what you will be shooting if a wide aperture is wanted. When using a tripod and shooting stopped down most of the time I can not believe the Tokina will be of better use :?
I can imagine if distortions are less, that you would therefor choose the smaller range.
- Wout -
